Advice for Migrating to SSD
Solved by SlayerOfHellWyrm,
Just for the future, if you ever need a product key, you can use Magical Jelly Bean Key Finder. As for the rest of the post, I'm unfortunately unable to help you, as I've never migrated to an SSD, I've always just done clean installs or clones.
EDIT: Nevermind, like I was going to assume, you can use EaseUS Todo BAckup Manager. Better explained in this great Lifehacker post Basically, you're copying things to an external, whatever won't fit on the new, of you don't want on the new, then wiping it off the original drive, and cloning the remainder to the SSD.
