So I'm pretty new to building computers and such, I've built a few with help and my last build I did by myself but the parts were given to me. Now I'm building my own, on my own terms. I've nearly completed my build but there's a few things I would still like to get, Such as a Cpu Cooler. I'm currently running an AMD 8350 and would like to overclock it to 4.0GHz or higher. With that being said, I know this Cpu can get hot, thus the reasoning I want a Cpu cooler before I overclock. I've had a look around and was thinking about getting the 212 Evo but wanted a second opinion before buying. I prefer if it was Air cooled (a little scared to try water cooling). I would like to keep it under $100 but am wiling to pay more if need be. Any suggestions would be most appreciative!
https://linustechtips.com/topic/181257-need-help-picking-out-a-cpu-cooler/
Nh-d15, or a be quiet dark rock 3/pro. Even a cryorig r1 ultimate for better looks than the noctua and ever so slightly worse performance.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
As I said I would love to get a NH D15 or the Dark rock 3 but those are just to big, I would need something a little smaller.
NH-U14s
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
The 212 Evo is fine for that. You should be shooting for 4.4ghz+ though.
NH-U14s
^ this! or a dark rock 3 (non pro) if the clearance is okay. It is narrower than the dark rock pro 3.
PCs
Scythe Ashura , it's only $50~60 depends on location
CPU: Intel i5-4670K CPU Cooler: Swiftech H240-X Motherboard: ASUS Z97 Sabertooth Mark 1 Memory: Corsair Vengeance Pro 1866MHz 16GB Storage:  Samsung 850 evo 250GB ,1TB WD BLUE, Seagate Barracuda 2TB GPU: ASUS STRIX GTX970 4GB Case: Fractal Design Define R5 PSU: Corsair AX760 Full Modular Monitor: Dell 23" S2340L IPS Keyboard: Corsair Strafe RGB Mouse: Logitech G502(w/ Mi Metal Mousepad) Headphone: Audio Technica ATH-M50/MSR-7 Speaker: Edifier Studio 7 R2730DB
Try DeepCool's GamerStorm Lucifer or Assassin... It would only set you back 30-60 USD>..
Also @KangNanTee, do you play KanColle too?
Yes i do play , it's a addictive browser game
I am currently using an AM FX-8320 CPU at 3.5GHz with an H80I push/pull liquid cooling setup,
Temps for me are:
While browsing web: 10-25 Celsius
Tomb Raider: 30-40 celcius
Planetside 2: 35-50 Celsius
Metro Last Light: 30-40 celcius
Arma 2/DayZ Standalone:  30-40 Celsius
The installation was pretty easy, and this was my first time ever installing a liquid cooled set up.
