Tweezers and patience is the only way to go
SUCTION CUP
If tweezers dont work then you're pretty much screwed.
Hi guys
i need help on how to remove the end of my broken mic jack in my mother board tried using tweezers still cant get it out
thank in advance
It depends which portion broke off if it's the whole jack a pair of tweezers may work or precision pilers will work better since you can apply more pressure when pulling.
If the tip broke off you may need to try and access it via the rear of possible to push it out if it's not possible then you can try the solder and wire method but it's very risky in damaging things from heat.
http://www.instructables.com/id/Pulling-out-tip-of-a-broken-35-jack-connector/
If you become desperate you could get a soundcard and plug it into that.
Or simply use the front one.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
When i did this to my Sub i found a small screw and screwed it into the snapped jack and pulled it out with pliers.
Where do bad folks go when they die?
They don't go to heaven where the angels fly
They go to the lake of fire and fry, Won't see them again 'till the fourth of July
