JetFlos are more for case fan use not for coolers
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Changing it to jet flows would do nothing for performance as the fan is already realativly ok and jet flows arnt exactly amazing. If you are gonna change the fans you may aswell change them for something high end, like noctua of noiseblocker.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
Buy a better cooler instead of getting a replacement fan for 20 bucks.
Seriously a better fan on a hyper 212 does so little.
{PC} i5 4690 | Gigabyte R9 290 | Asus H97-Plus | 8GB Kingston HyperX Fury | CM Hyper 212 Evo | Samsung 840 Evo 120GB | Adata SX900 256GB | Seagate Barracuda 2TB TT 650W Smart Fractal Design Define R4 Windowed
{Audio} Ear/Headphones: HiFiMAN HE-400, Westone 4R, Shure SE535 Amp: Little Dot MKIII, Fiio E11 Dac: LIttle Dot Dac II
stock fan on this is already pretty good and quiet you know? you should try it first..
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
You should upgrade to the nzxt havik, 3 degrees lower than noctua and only 60 bucks also looks tight.
i agree the havic is awesome, same goes for the be quit dark rock 3 pro, but both cost more than a 212.. :)
