Hello, just built my first PC, got a AMD Athlon 760k for my CPU and I got a Cooler Master 212 EVO to deal with AMD's cooling problems with its processor. I turn on the computer, and open Windows 8.1. I go to the temps and they are 55, next time I look their at 80, then down to 73, down to 49, and back up. This is happening when it's idle, it even got up to 91 degrees which scared the hell outta me. Funny thing is, my case seems pretty cold every other component is below 30 degrees, but the CPU is just going everywhere. Perhaps the CPU cooler wasn't good enough, or I just need to reassemble the cooler, and to let you know, I used Arctic Silver thermal paste instead of the normal cooler master one that gave.
The temperature varies from 49-91 degrees Celsius, at 91 I usually just restart the computer to avoid damage.
Thank you to all who may respond
https://linustechtips.com/topic/178486-super-scary-temps-on-cpu-need-help/
im sure its either a bad mount or too much termal paste how much did u use?
remember a drop is more than enough
try remounting if the problem persists its probably a faulty sensor
"I've been mad for fucking years, absolutely years, I've been over the edge for yonks..."
"I've always been mad, I know I've been mad, like the most of us are...very hard to explain why you're mad, even if you're not mad..."
"There is no dark side of the moon really. Matter of fact it's all dark."
So at idle it just does this? Go to task manager and wait til your temps spike and see what's causing the problems..
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
I do remember seeing when I put it up that the thermal paste was kind of going a bit over when squeezing, I made a square as thin as I could, probably not thin enough.
You are only supposed to apply a pea sized amount on the center of the CPU, the force of mounting the Cooler takes care of everything else.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
Crap, ok, I'll just shut off the PC and wake up tomorrow and hopefully fix it. Hopefully no damage is done to the CPU at these temps.
nope dont worry its not damaged, just use a drop of thermal paste
Although Linus was way too liberal in that video.
If you continue to have this problem...then I suspect its just bad readings on the richland. I just made a post with the same issue....its been happening since the start, even with the 212 correctly mounted and pasted.Check my post out and see if it looks familiar.
 http://linustechtips.com/main/topic/178583-amd-athlon-ii-x4-760k-idle-at-55c-under-load-at-70c-normal/
