Hi guys i need some help in choosing a heatsink for my cpu, max $80
These are some options i have, but you can suggest me other than the ones in the list.
beQuiet! DarkRock 3
beQuiet! ShadowRock Slim
Cooler Master Hyper 212 EVO
Noctua NH-U12S
Noctua NH-U14S
Thermalright TRUE Spirit 140 POWER
This is the rig i am going to build: http://pcpartpicker.com/user/mosin40/saved/fNpmP6
https://linustechtips.com/topic/178348-cpu-cooler/
change that i5 for a devils canyon. and the thermalright true spirit 140 power
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2394733
beQuiet! DarkRock 3
Noctua NH-U12S
Noctua NH-U14S
IMO, U14S hands down. That thing whoops the H100.
"Rawr XD"
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2394768
beQuiet! DarkRock 3
Noctua NH-U12S
Noctua NH-U14S
The U14s is hands down the best in every department on that list.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2394860
Good cooler, but it is out of my budget for the cpu cooler, $80 max
Take a look at the NZXT HAVIK it is a good cooler competes with noctu and loses to a 100i but 1 degree. Its also only $60 and looks sexy , not dark rock sexy but still nice.
† TTCF Member † Jesus loves you! Have a good day and stay techie!
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2394976
beQuiet! DarkRock 3
Noctua NH-U12S
Noctua NH-U14S
U14S. But it doesn't whoop the H100i, it's slightly below it performance wise being a single heatsink air cooler and all. The NH-D15 whoops the H100i.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2395350
Noctua U14S if you don't mind the fan colour  :)
Also that GTX 760 4GB gpu is pretty pointless. The MSI GTX 770 is the same price.
 http://pcpartpicker.com/part/msi-video-card-n770tf2gd5oc
I would go for a 280X though and save a bit more money.
http://pcpartpicker.com/part/asus-video-card-r9280xdc2t3gd5
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2395652
and the windforce 290 is the same price as a 770, so get the 290!
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2395661
If you consider the noise it makes and it's performance, it whoops the h100i though
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2397945
Anything from noctua. :-) and then as big as you can depending on your case. So nh u14s would be the best.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2398308
I know that the r9 280x is the best price/performance gpu for 1080p.
I am planing to buy ASUS' ROG Swift 2560*1440 monitor, so an NVIDIA gpu would be better for me so I can take the advantage of G-SYNC
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2400184
You won't be maxing out that resolution with a gtx 760 though.
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2400454
Yeah i know, I want something like a gtx 780/780ti
Yes a 780 or 780 ti would be a better choice. If you swap the Seasonic psu for the one below, you will have enough power for SLI.
Fully modular with a 10 year warranty.
http://pcpartpicker.com/part/evga-power-supply-220g20750xr
https://linustechtips.com/topic/178348-cpu-cooler/#findComment-2402171
