Semi-Pro Sound Recording Solution
http://www.amazon.com/gp/aw/d/B002QAUOKS?cache=f3d8f739bae20e1ff47a47684a198f2eπ=SX200_QL40&qid=1404861693&sr=8-1#ref=mp_s_a_1_1My budget is around $500. As for what I want to record, mostly vocals. I am starting to get into podcasting. Also I need a better microphone for video voiceovers, specifically used in tutorial videos, which vary from Linux tutorials all the way to math, science, and even some programming.
So far I have been using my headset mic, and the audio recording is just bearable.
http://www.amazon.com/gp/aw/d/B005OZE9SA?pc_redir=1404789450&robot_redir=1
If the mobile links don't work for you, that's a focusrite Scarlett 2i2 and a Rode NT1A mic pack. Should get you all set. You might need a stand and an XLR cable, but they're not expensive. Does that look good to you?
I use the NT2A at school a lot and it's one of my favourite go to mics for practically anything. The NT1A doesn't have the versatility in the same way, but it definitely sounds great.
