Hey guys, so I am currently in an RV park for the time being and I paid to use the wifi here. Now the problem is, I can only use one computer and one Tablet or phone on said connection, it has a server lock of some sort stopping me from adding more. SO i was wondering, is there anyway I could cheat the system so i could connect more of my computers? I personally wouldn't mind only having one PC and one Tablet as my options, but I have a family of five. So do you guys know of anyway that I could cheat the system tat would allow me to connect more computers? I would prefer it if I wouldn't have to buy anything.
https://linustechtips.com/topic/177670-cheating-the-wifi-system/
i  forgot the name but yes there is a way ( software)
basically taking the wifi and u can send the net via ethernet or if u have a wifi adapter (usb) u can send the signal
edit found it
http://www.connectify.me/
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384441
Connect your laptop to the Wifi, connect your tablet to your laptop and share the connection, make your tablet a hotspot.
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384450
Also, I'm not sure the tablet can be made into a Hotspot. It is an older 2 gen ipad.
as far as i know devices cant use the same "medium" in order to share the connection
ie wifi - ethernet (vice versa)
3G to wifi   (vice versa)
but not wifi to wifi  (special circumstance wifi extenders)
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384492
Now see, that would be the problem. The iPad doesn't have 3G. Well, it was worth the try asking, thanks anyway.
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384516
You can It's just that you need Kali Linux or a DD-WRT router to do a virtual AP on the same interface.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384576
you would bridge your wifi to your ethernet and then connect that to a router and thus you can have wifi on all your devices. as far as having more than one per login that is a mac number lock. thats how they make sure you dont connect more than one device. and its hard to bypass as its software running on the server and thus is controlled.
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384690
Something like this might be a solution next time
http://www.amazon.com/gp/product/B00DTPYRTI/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B00DTPYRTI&linkCode=as2&tag=barnacnerdg08-20&linkId=MPA7UOVMBMBBFWSI
Saw it rewieved by Barnacules about 2 weeks ago -
Haven't looked into possible alternatives, as i hadn't had a use myself - but i'd suspect that similar products exist.
/Dennis
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2384767
Hmm aren't we jumping on our guns here? Pretty sure if you can connect to wlan... you can also make hotspot with the same hardware... try something like this
https://www.youtube.com/watch?v=jdSm0C919PM
PLEASE QUOTE OR TAG (WITH @) ME IF YOU REALLY REALLY REALLY WANT ME TO REPLY!!!!!!!
Also if your issue is solved don't forget to mark the thread as solved!
Peace!!! from a random person in the tech's god forsaken land (named Finland or as I like to call it sarcastically FUNland)
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2385177
look up open garden. I couldnt get it to work a while ago, but that was close to a year ago and beta. worth taking a look though
https://linustechtips.com/topic/177670-cheating-the-wifi-system/#findComment-2385233
