Im making this post for a friend, this happens when he plays call of duty ghosts sometimes and he said on dayz sa he gets green dots everywhere when the gpu gets hot (still trying to get a screenshot of that) he has adequate cooling and his gpu never goes above 80 degrees. Is this a problem with the card what could he do to fix it and is it rma time?
post-66710-0-16851800-1404750141_thumb.j
https://linustechtips.com/topic/177623-r9-280x-problem/
Artifacting.
Turn down the GPU clock and turn up the voltage.
Put it back to stock if it is overclocked.
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383643
Which brand is that?
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383739
asus windforce r9 280x
Asus doesn't make WindForce.... They make Direct CU II.  Gigabyte is the company that manufactures WindForce.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383773
He said asus windforce and i just carried it over without thinking.. But he just said it iS direct cu II.
Interesting.  Asus is usually a great manufacturer.  This is the kind of stuff I'd expect to see from the likes of Club 3D or Zotac.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383807
Asus 280x.. i'm totally not surprise.  :D Get a refund better, their 280x is problematic.
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383817
Those asus 280xs are faulty, Something with the cooler not making contact. What is happening is the card is getting to like 85c and hotter and he must not be realizing it which is what is causing the artifacting. Used to happen to me when i was pushing my 7950 to its limit.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383848
He said it started messing up on dayz at 62 degrees.
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383880
What is he using to monitor the temps? He could have burnt the chip out which will lower its stability at stock clocks. Either way he is going to need to rma.
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2383947
Asus 280x was plague with artifacts issues related to VRAM and BIOS issue. I think BIOS issue was fixed but not VRAM. Pray he didn't get same problem with new card after RMA.
https://linustechtips.com/topic/177623-r9-280x-problem/#findComment-2384040
