What do you think of this setup?
Motherboard: MSI Z87-G45 GAMING, LGA1150, Intel Z87, DDR3, ATX
Cpu: Intel Haswell Core i5-4440, LGA1150, 3,1 GHz, 6MB
Gpu: MSI NVIDIA GeForce GTX780 Twin Frozr 4, 3GB DDR5 , 2xDVI/HDMI/DP, PCI-E 3.0
Ssd: Crucial 240GB M500 SSD, 2.5", MLC, SATA III, 500/250 MB/s
Hdd: Seagate 1TB Barracuda, 3.5", Sata3, 7200rpm, 64MB
Psu: LC-Power 650W, LC6650GP3 v2.3, Silent Green Power ATX
Ram: Corsair 16GB (2 x 8GB) Vengeance Blue, DDR3 1600MHz, CL10, 1.5V
Case: Fractal Design Define R4 Arctic White ATX
and for peripherals: SteelSeries Frost Blue Bundle Box (SteelSeries SiberiaV2 Frost BlueEdition headset, SteelSeries Sensei[RAW] Frost BlueEdition mouse, SteelSeries QCK Frost BlueEdition mousepad) ,SteelSeries Apex [Raw] Gaming Keyboard
https://linustechtips.com/topic/177448-my-first-build/
if you don't need to OC
I don't see the need for a Z87 board use a H87 board
8GB of RAM is really good enough
edit change out the PSU
LC are rated by Jonnyguru as trash
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381315
loiveli, on 07 Jul 2014 - 12:59 AM, said:
Ok thanks for tips.
Btw what psu you would recommend.
Corsair is really good.
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381345
The PSU will turn this thing into a bomb. Look at some PSUs from Corsair (great), CoolerMaster (good), XFX (great-ish), Seasonic (best) or EVGA (good).
Since you aren't gonna OC with that CPU get a H87 or H97.
If you aren't going to render get 8GB of RAM.
What is your location and budget?
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381359
ok
get this or the CX600
http://pcpartpicker.com/part/corsair-power-supply-cx500m
I second everything dragooon said.
its Dragoon or dragoon
too many Os
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381373
Finland and 1500(about 1800 dollars) euros for EVERYTHING exepct display and windows.
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381375
Is that enough?
yes 500 watts is enough with your system
if you want to OC the GPU
then get the CX600 Watts version
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381390
My stepdad said this would be good for my build: Corsair 650W, VS650M, ATX
and i chose this for my new motherboard: MSI H87-G43 Gaming, LGA1150, Intel H87, DDR3, ATX.
What do you think?
VS is not 80 plus rated don't buy it
VS series is not great; I'd get a Seasonic 520W S12II-520 instead.
Seasonic or the CoolerMaster VSM550
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381432
Ok thanks for your tips right now my setup looks like this:
Motherboard: MSI H87-G43 Gaming, LGA1150, Intel H87, DDR3, ATX
Psu: Corsair 650W, CS650M
any ideas to improve it even further?
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381460
I'd change the PSU to the Seasonic 550W G-550 modular because at least in the store I'm looking in it's cheaper than the CS650M and better.
Edit: what store will you be buying from?
https://linustechtips.com/topic/177448-my-first-build/#findComment-2381471
