So I started building a system with an amd processor and it does not want to boot. I think it is the cpu because if unplugged the system keeps running but when plugged in it boots into bios and turns off. The cpu is also extremely hot.
https://linustechtips.com/topic/170610-help/
please only post one tread. if you are curious about our rules please refer to the COC thread.
do you have the cpu cooler installed? are all power cables connected to the mobo, 24 pin + 4(or 8) pin?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/170610-help/#findComment-2266959
Sorry for the double post I pressed back and posted it again on accident. We have the heatsink installed and everything is plugged in
https://linustechtips.com/topic/170610-help/#findComment-2267018
check your ram sticks. plug one in and power on and see if it boots to bios.
https://linustechtips.com/topic/170610-help/#findComment-2267032
One didn't change anything.
can we get a pic of the mobo?
https://linustechtips.com/topic/170610-help/#findComment-2267047
I'm on a phone and its not allowing me to input a photo. I can text you it if that works for you
youll need to click full version at the bottom of the page and navigate to more reply options were you will be able to upload a pic.
https://linustechtips.com/topic/170610-help/#findComment-2267085
Did it help?
Nope. I just like to see pics of people's rig. Everything in the pic looks right.
https://linustechtips.com/topic/170610-help/#findComment-2267490
