So currently im using a stock intel cooler in my system. Does that cooler add heat inside the case? To the point that it is affecting the temps of the gpu because of the high temp inside the case?
Developer by day, Gamer by night
CPU - Intel i7 4770k | MOBO MSI G45 Gaming | RAM - G.Skill RipJaws X 1600mhz 4x4gb CL7 | CASE - NZXT H440 | GPU - MSI R9 290 | PSU - Corsair RM850 | SSD - Samsung 840 EVO 128gb | HDD - Western Digital Black 2TB
https://linustechtips.com/topic/168480-stock-cooler/
What is the temp in your case?
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241343
mmhm? stock coolers aren't pointed directly at the gpu so i hardly believe that it would be pushing the gpu temp higher though if you feel that your ambient tempts inside your case are to hot get a few exhaust fans in there and make sure your room is vented.
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241349
I wasnt able to measure it exactly, but the exhausted air is so hot that i assumed the temps inside is high.
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241358
Do you have your CPU or GPU overclocked?
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241362
Yeah i know it's not directly pointed, but it still contributes to the heat inside right? So yeah, maybe i should add a few exhaust fan. I only 1. The top rear exhaust 140mm fan.
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241363
None. Im not going to OC on a stock cooler. Haha. Same on my gpu, no OC
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241367
any fan would contribute to heat. Cpu gets hot>fan/heatsink dissipates air>hot air goes into case>needs to be exhausted out. I'd also recommend getting a brown and ugly cpu cooler for some overclocking goodness, otherwise that unlocked cpu will go to waste.
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241376
What is the temp of the computer? Check with some software or something.
You should definitely get a CM Hyper 212 EVO at the least. It will do your build wonders and another fan blowing in fresh, cold air maybe?
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241386
Im saving up, then i will get an AIO. :)
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241388
Try filling your case up with fans in all the available spots. As long as you have good airflow through the case it will not heat up as much :)
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241391
I wasnt able to measure temps exactly, but the exhausted air is so hot. So that's how i figured it out. Also i will be getting an AIO.
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241396
You can measure temps with a software installation, like CoreTemp, RealTemp etc etc. An AIO will work too. :D
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241431
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241432
snip
AIO = Looks and Performance. Sorry man :P
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241504
nevuh, noctua fanboyism for lyfe
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241509
But but but in you sig, it says Corsair H100i as an "Upgrades to come"
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241533
yea but it will have some ugly brown fans on it, so it balances kinda?
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241539
Oooh. Yeah, if those industrial PPC fans come here, i'll buy 5 of those. :P
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2241554
Measurement by hand is most inaccurate way to tell temps. Your body temperature is around 35-37C. Anything with that temp already feels hot. 40-50C is pretty much normal idle/light use temp with stock cooler or non-ocd GPU. Under full load temps should be under 85C for GPU and under 75C for CPU.
With some thermal probes I have determinated that area near source of heat (core) is about 10C lower. Intake over HDDs is around 40C depending on your ambient. So exhaust with temps around 45C seems normal to me.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2242354
snip
The case was hot as hell too. Especially on the side where the GPU is. After looking at HWMonitor, 70c-80c on the CPU. 80-88c on the GPU.
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2242601
Ok, then you should worry and see if you can improve cases general airflow.
https://linustechtips.com/topic/168480-stock-cooler/#findComment-2242807
