GPU temp overheating while load (almost instantly crash)
If that is actually what's wrong I don't think there's much you can do short of trying thermal adhesive with a clamp and letting it sit overnight. That would be last resort measures because that stuff is permanent. How long have you had the card? EVGA offers a three year warranty on most of their cards.
that warranty was probably voided by the conductive tim he used previously.
Is there any fix I can do about it?.
If your card has indeed warped, which seems to be the case, you need to find a way to get the cooler to be touching the gpu at all times (for obvious reasons), you can try with a round or two of electrical tape around the card and the cooler and squeeze it as thight as possible. if that doesn't work, try the same trick with the case in a horizontal position. If that doesn't work either, try placing some sort of holder under the card and resize it until it fits perfectly. If none of that works, your last resort would be to glue the card in with thermal adhesive as JamGorby said, but as he said, it's permanent. If THAT doesn't fix it, you're screwed period.
