There's go to be a safe way of doing it, it may not be pratical, but there has to be
Its not putting the PC inside the fridge, but putting the fridge inside the PC!
Like this:
ld-pc-v2-phase-change-white-xl-suction.j
http://linustechtips.com/main/topic/7060-my-phase-change-cooled-custom-test-bench-system-with-3930ktitan/?hl=phase+change
https://linustechtips.com/topic/167949-extreme-watercooling/#findComment-2234373
your best bet would be a freezer and you would have to run antifreeze.  It would be your rads that would go into the freezer not your pc.  You can have all the condensation you want on them.  But the pelltier coolers that are used to cool the fridge and freezer down are not enough to counter the heat of a pc in a sealed area like that.  So big rads for reservoir and you will be able to keep the liquid cooler longer.
In another thought you really wouldnt get that much of a temperature drop and eventually you will catch up to ambient temps.  The setup you would need to get long game time out of would have to be pretty big.  You would be just as well to do a custom loop.
You could also do a thermal electric setup (Just the peltier cooler)  You would have to worry about condensation and whatnot.  I have seen videos where people just apply vaseline to the mobo and heat it with a hair dryer to cure dry and seal it.  I can imagine you would want to only have your temp just below actual freezing to minimize condensation.  Better them room temp tho.
https://linustechtips.com/topic/167949-extreme-watercooling/#findComment-2234422
I've seen them put the rads inside the freezer...but, couldn't you slobber the whole PC in that protective gelotin that protects the comp from the liquid nitrogen?
At some point this stuff isn't practical or even useful. Sure throw Vaseline on everything, heat up your fridge and use more power. What you're getting is slightly better, more expensive and hassle full version of water cooling. Water cooling is really enough for the hardcore, everyday user while ln2 and phase change is for the crazies and professional overclockers. It's best to throw a custom loop in a be happy.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/167949-extreme-watercooling/#findComment-2234962
Well, hey man. If Linus can put SLI and Crossfire in one computer, why not put a whole one in a refrigerator
He won't do it, because it is hard, seriously impractical and not worth his time. Just like the oil PC, we would all love to see it although we all know how to do it. But it isn't worth it from his point of view.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/167949-extreme-watercooling/#findComment-2235392
