Okay? Yes. Good? No.
Why did you buy the DCU II? They are well known to have thermal issues, making them no better than reference.
https://linustechtips.com/topic/166415-temps/#findComment-2214867
Technically it is since Hawaii can run at 95c, but personally that's too hot.
That's strange for an aftermarket cooler to run that hot.
https://linustechtips.com/topic/166415-temps/#findComment-2214868
Is 94C on Unigine valley benchamark ok for a Direct CUII 290? Yes I know it runs hot, but I am just wondering if it is safe. :/
94C is hot, pretty sure the R9 290 is designed to run up to 95C, but max out at 100C.
I know you're running a benchmark, but that is hot, in my opinion.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/166415-temps/#findComment-2214870
That's pretty average for a 290. They usually linger around 90-95c on stock cooling, but since the DirectCUII is known not to work well with AMD video cards, this would explain your temps.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
https://linustechtips.com/topic/166415-temps/#findComment-2214871
It looked nice and is quiet.
Fair enough.
Well, as hot as it is, it should be fine.
https://linustechtips.com/topic/166415-temps/#findComment-2214878
