Why call it Project Multipass?  That because the guy I built this for hasn't seen The 5th Element.  I know, I was surprised as well.
OK, now to the things you care about.
With a budget of £900 the parts list look dumb but hopefully you'll see why further down the page.  I replaced the blue power LED with a red one to match the colour scheme for the build, there is also a red LED strip on the roof to illuminate the inside.
Specs:
Case: Fractle Define R4 (With a windowed panel)
CPU: Intel i5 4670K
MOBO: MSI H87-G43
GPU: MSI R9 270
RAM: 8GB Corsair Vengance
PSU: Silver Stone Strider Plus 500W
HDD: WD Blue 1TB
SSD: Samsung 840 EVO 120GB
ODD: ASUS x24
CPU Cooler: BeQuiet Dark Rock Advanced
Other Parts:
Akasa red LED strip
MDPC-x sleeving and heat shrink
So this was my first time sleeving cables, considering this I am really pleased with the results.  Decided to go with shrink-less sleeve as I fell it has a nicer aesthetic.  The cables are tied together using linen thread, local craft shop didn't sell waxed thread, but it worked really well.
Pictures, YAY.
Here's a view of the inside.  Sorry about the shadows I couldn't find a reflective screen.
Another of the inside, just a bit lower.
A close up of the 8PIN Power
Close up of the cable sleeving.  Just ignore the blue plug that I coloured with a Sharpie, you don't notice it with the side on.
Cable management for anyone who was wondering.
Well that's it nothing crazy or elaborate but I like it.
Thanks for taking the time to look through my build.
Cheers
Morphis
https://linustechtips.com/topic/165801-project-multipass/
That cable sleeving is beautiful.
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206758
Nice Clean build I like it a lot :)
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206761
BEAUTIFUL
I really need to sleeve my cables and get rid of the annoying stiff ones my corsair psu came with
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206776
Great job on the custom cables :)
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206862
BEAUTIFUL
Stiff cables hold their position better without need to sew them...
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206863
Yeah but are a bastard to bend, they do not "flow" like the cables in this case, some are flat ribbon cables and t hey are really annoying, because when you bend them they just kink out and makes space behind the motherboard really tight
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206876
Yeah :(
https://linustechtips.com/topic/165801-project-multipass/#findComment-2206896
The sleeving helps hide the small kinks.  I remember using a sponge and a pen to try and flatten out IDE ribbons, it was a pain in the arse.
https://linustechtips.com/topic/165801-project-multipass/#findComment-2208835
Looks, great man! Nothing hints that it is a 900$ build.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/165801-project-multipass/#findComment-2215436
That sleeving is so nice.
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/165801-project-multipass/#findComment-2215512
Nice clean build, I've just finished my own one in an R4 and it's a lovely case but my cables let it down a bit. Love the sleeved cables, you've done a great job! I'm trying to find some to buy off the shelf as definitely wouldn't get a result like that doing them myself but there doesn't seem to be many places in the UK that do custom cables apart from the Corsair ones or extensions so if you ever take it up as a job I'd be interested  ;)
I may post my build up at some point but looks so tame compared to most on here lol. Anyway great job on this.
https://linustechtips.com/topic/165801-project-multipass/#findComment-2226381
Yeah I don't know of anywhere here.  I know corsair and NZXT sell sleeved cables for their modular PSU's, and I believe SilverStone do as well, which is fine if you have one of their PSU's anyway.  Extensions would make sense though, if you don't have the time to do your own.
That's why I wasn't going to post this build, because it doesn't have watercooling of mods or it's really expensive.  But people seem to rate the build on it's own merits, instead of hating because it's not balls to the wall crazy.  Which, along with the community, is nice.
https://linustechtips.com/topic/165801-project-multipass/#findComment-2229804
Can the beQuiet mount so it's taking in air from the front rather than off the GPU?
Yeah it can.  Ive mounted it like that partly for aesthetic reasons but also for compatibility.  The fan was hitting the RAM when mounted the other way round, though it should be fine if you have low profile sticks.
That's some amazing sleeving. I was looking for something just like it.
Cheers man.  :)
https://linustechtips.com/topic/165801-project-multipass/#findComment-2231577
I hate to be unoriginal, but yeah, those cables, especially the bend
for the EPS and GPU cables, really nice indeed. :wub:
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/165801-project-multipass/#findComment-2239437
