I am building a new pc would anyone help me upgrade it to the best it can be? Spec so far:
-Intel cor i7 4770k
-Asus maximus vii hero
-Microsoft windows 7 home premium sp1 x64 english 1 pack dsp oei dvdlcp
-Nzxt phantom 820 full tower
-Corsair CP-9020062-UK RM Series RM1000 80 Plus Gold 1000W ATX/EPS Fully Modular Power Supply Unit
-Samsung 840 EVO 250GB 2.5 inch Basic SATA Solid State Drive
-Western Digital Velociraptor - 1TB Desktop SATA Hard Drive - OEM
-Corsair CMZ16GX3M2A1600C10 Vengeance 16GB (2x8GB) DDR3 1600 Mhz CL10 XMP Performance Desktop Memory Kit Black
-Asus Blu-ray Writer Drive (S-ATA, BD-R: 12x, DVDR: 16x, CD-R: 48x, Drag and Burn, QTS Technology)
-Corsair Hydro Series H100i All-In-One 240mm Digital High Performance Rad Liquid Cooler for CPU
Now if there is anything that can be changed for the better please let me know as i want my pc to be the best it can be, would appriciate it so much.
Thank you.
https://linustechtips.com/topic/163759-pc-build-help/
These specs look good so far (Y)
CPU: AMD 5790t Motherboard: Gigabyte Forumlar XII RAM: Ah Whole set of it GPU: GTX 290x Ti Storage: Ah Ton of HDD PSU: Once it on Display(s): Well I still seeing pixels Cooling: It running COOL BRO Keyboard: *click* *click* Mouse: MORE *click* Sound: OHH DE BASEE
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2178652
I don't see a gpu. And psu is WAAAY overkill. Do you need a blu ray drive?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2178735
budget?
location?
uses?
use the quote button if you want my help
Specs
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2178837
budget?
location? Basildon, essex
uses? Everyday gaming
You could at least answer @SAV1OUR.
Edit: Nevermind.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179815
budget? Don't have one as I will save until I have enough as I want the best
location?
uses?
Save money and get a cheaper motherboard, add a GPU- The iGPU in the CPU is crap, and the PSU is overkill. Otherwise, it's a pretty good build.
what is GPU? I'm new to building PC's but I have had my current gaming PC for a while and would like to get a better build now
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179820
GPU = graphics card
generally a 500 to 600 watt power supply which is gold rated is more than enough
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179834
isn't the GPU the gtx 780ti?
well i don't see it in your original post
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179848
would a 1000w mcorssaire power supply be enough?
if you are just running on one 780Ti then you don't need 1000watts unless you are trying to do a three or four GPU setup
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179851
what ways would be best for me then?
any good 550w
Specs
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179878
oh yeah haha just looked and it wasn't listed haha sorry about that, also what PSU would you recommend?
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($314.99 @ Newegg)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Amazon)
Motherboard:  Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  ($209.99 @ Amazon)
Memory:  Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($149.99 @ Newegg)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Drive  ($134.99 @ Best Buy)
Video Card:  EVGA GeForce GTX 780 Ti 3GB Superclocked ACX Video Card  ($679.99 @ NCIX US)
Case:  NZXT Phantom 820 (Black) ATX Full Tower Case  ($199.99 @ Mwave)
Optical Drive:  Asus BW-16D1HT Blu-Ray/DVD/CD Writer  ($74.99 @ Newegg)
Total: $2029.14
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-09 02:08 EDT-0400)
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179886
any good 550w
Linus recently reviewed the CoolerMaster VSM 650Watt
been using CoolerMaster products, nvr go wrong with them
https://linustechtips.com/topic/163759-pc-build-help/#findComment-2179891
