Please read before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
This belongs in the New Builds and Planning section. I'm moving the thread.
Please post in the correct sub-forum in the future. Guides and Tutorials is for posting guides for others to see and not for asking for help.
Welcome to the forum, we really can't help you with just that info.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
Im sorry if I messed up im not use to these things T.T i didnt know where to put this so I just put it somewhere im sorry!
I need everything for the computer and what I was planning every month or 2 I would buy a part in 2 months time I could prob get 300 saved up ik this isnt much info I just want to know what basics I need to know to get the right computer aand im ssooo sorry im new to this kind of thing > . <
if you budget is 300usd for everything including peripherals and os, I don't think it would be sufficient.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
Not even if I buy a part at a time over a long peroid of time?
Not a good idea considering that you should want to test out parts asap in case they arrived defective and parts getting cheaper and better over time.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Just save your money and you will have a much better PC. Imo buying parts over a long period of time isn't really a good thing to do because chances are something new will come out and then the parts u bought already are outdated. I suggest save about $200 more dollars and u can get a decent rig @WoodenMarker also makes a good point about parts might being defective and then you can't return them
Life.exe is missing
technology gets improved over time which means that you're better off just saving your money and buy everything at the same time instead of buying each part seperate when you get the money for it. save your money and try again when you have enough to actually buy everything.
for reference
CPU:  AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.74 @ Amazon)
Motherboard:  Asus A78M-A Micro ATX FM2+ Motherboard  ($59.79 @ Newegg)
Memory:  Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Micro Center)
Video Card:  PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($129.99 @ Newegg)
Case:  Cooler Master N300 ATX Mid Tower Case  ($55.98 @ Newegg)
Power Supply:  Cooler Master GXII 550W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Micro Center)
Total: $546.44
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-08 23:34 EDT-0400)
this have not included OS,mouse,keyboard and monitor
but this is a solid all rounder system
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
