Hey y'all. I just ripped a couple of sticks of ram out of an old surveillance server. The Exacqvision, model ip04 18t r2a, to be exact. No pun intended.
Anyway, I googled every code on the label and even the ram chips and can't find a match. I was hoping someone here may be able to help me identify them.
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
https://linustechtips.com/topic/1635910-help-identifying-memory/
Probably DDR4 4GB based on similar parts. If you have a DDR4 system stick it in and read the SPD. BIOS might show it, or use CPU-Z.
The 1.2v tells you it's DDR4 , DDR3 is 1.35v or 1.5v
cbd26d4u9s1ka - 26 makes me think it's default 2666 mhz , and the small amount of chips on the stick hints of being 1Rx16 which is a bit lower performance than 1Rx8 and ideally not mix them in same computer with 1Rx8 sticks. The 4 is probably for 4 GB.
Google search for that code gives recommendation for an Ateam 4 GB DDR4 2666 Mhz pair and the description says compatible with Kingston ACR26D4U9S1KA-4    https://atechmemory.com/products/acr26d4u9s1ka-4-kingston-1x-4gb-ddr4-2666-dimm-pc4-21300-single-rank-x16-module-equivalent?srsltid=AfmBOooOr8GwGFX0GtDGJYjtOfj5EyNvx9wsKRTZR4p5dnBEMNDreGuP
Thanks y'all.
As the server was no longer operational, I was able to get the sticks into a working system and tested them out.
They're 2x4GB sticks of Kingston DDR4 2666mhz.
