Howdy! I got a brand new gigabyte oc rx 9060xt 16gb a few months ago. It's worked great until recently; Often when my pc has been running for an hour or so i start getting weird graphic glitches. When I enlarge or minimize apps, a buncha brightly colored pixels flash for a second before going away. Also, ive completely lost all feed to my monitor a few times recently (black screen). Is this a simple matter of reinstalling drivers, or is there something truly wrong with my gpu? Thanks!
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/
Try all the basic troubleshooting stuff like driver updates and all that, then come back. We have to eliminate possible causes before we can find the answer
Currently Playing: Doom (2016)
Currently Listening To: Proof, Led Zeppelin
Hardware/Software: running old laptop with Ubuntu Server to run copyparty and a Terraria server, Steam Deck and high-ish end Windows 11 PC for gaming and content creation, Dell Inspiron laptop running Arch for school. Diehard iOS user, I lowkey want a mac too
PS5/PS2/PS1/Xbox/Xbox 360/Xbox One/Wii/N64/Switch/Powkiddy V90/
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/#findComment-16868341
Sounds to me like VRam trouble.
I wonder if you get the VRam temperature (with HWiNFO64 ?).
If not I'd consider opening the gpu and checking the thermal pads.
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/#findComment-16868365
Try a different cable, it kind of sounds like signal integrity and should be easy to test
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/#findComment-16868391
I know there have been issues with the gigabyte "server grade" thermal paste, but my card is mounted horizontally and i rarely push it very hard.
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/#findComment-16868426
You probably mean thermal putty
When you launch HWiNFO64 you can chose which part to launch, chose "sensors"
Edited by leclod
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/#findComment-16868536
I am just going to say this, before you do any tinkering with thermal pads exhaust all possibilities and look into a potential RMA first.  I had similar issues with a really old sapphire Radeon HD 3870 back in the day and I just RMA'ed it rather than tinkering with any thermal paste stuff.
https://linustechtips.com/topic/1632656-issues-with-rx-9060xt/#findComment-16869055
