How do I know if my iPhone 17 pro max battery consumption is normal? I could be wrong or just paranoid but I want a way to know that it is normal. So far my use has mainly been social media light use like scrolling texting etc. and I usually have mobile data on and Bluetooth also. Is there a way to determine this? I am asking because it feels like it is draining faster than I personally expected now I could be wrong or paranoid like I said
https://linustechtips.com/topic/1632199-iphone-17-pro-max-battery/
You can get a general idea, but it will differ from what you see based on network connectivity strength. If you have a weaker signal, your phone will drain faster. If you use WiFi more, your phone will use less battery, etc etc. There's a ton of variables. You're likely just being paranoid, but if there's a way to check what apps are using the most power I'd probably consult that.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
There is no standard. Each person uses their phone in a unique way.
Setting --> Battery --> View All Battery Usage
And yes, @dizmo is correct about signal. The weake the cell signal is, the more of a battery drain there will be. But if you set your phone to primarly use WiFi, it's less of an issue.
