AC Servo problem
Good morning,
Me and my university team have in our hands a 3-axis CNC machine with 3 LS-174 servo drivers paired with an ls-785 master controller powering 3 panasonic MINAS s series 100v 3-phase AC Servo motors. The machine comunicates with the PC through RS232 serial. One of the motors (MUMS011A1FOS) which includes an e-brake has trouble spinning, the e break works well but when we drive it through the LCDN utility (used for motor debugging provided by the motor driver manufacturer,I Logosol) only in pwm control and only in clockwise movement, the motor noise is just a little bit off and the motor heats up really fast. Counterclockwise, the motor doesn't even spin, it just jumps to a position and the program shuts it off. All three motors seem to be the same with 6.4ohm resistance from phase to phase but even when run by one of the other axis driver, the problem persists. To sum up, we have two problems on the table, the motor overheating (yes we tried PID tuning but since the windings seem to be the same we don't see how this would be different than the other two), and that the motor only spins counterclockwise when controlled through pwm but not when comanded to go in a given location (it just jumps and shuts off).
 Thank you very much for your time.
 Best regards
https://linustechtips.com/topic/1630732-ac-servo-problem-on-cnc/
