Rendering issues with most games causing low fps
Solved by OddOod,
On 11/4/2025 at 5:52 PM, DracoMalus said:if im upgrading then im not going back to intel, not anymore.
Outside of productivity or ignorance, no one is
On 11/4/2025 at 5:52 PM, DracoMalus said:what things are signs that it is?
Personally unsure, I dipped on intel after 8th gen. But you should be able to google "intel 14th gen degradation symptoms" and check for any of those
