I have a 2018 Nissan Rouge, I bought it off the lot in 2018. Today going to work the TPMS light starts blinking. I switch the display over to the Tire Pressures and notice one of the TPMS sensors is not displaying a tire pressure, a moment later it came to life. My question is what's the life span of the battery in one of these sensors?
Im wondering if the battery is getting weak and the colder weather is taking its toll.
https://linustechtips.com/topic/1624873-tpms-sensor-question/
The batteries in TPMS sensors are intended to last five to seven years.
My 2018 Chevy Volt did the same thing recently. I had a local tire shop replace all four original sensors. (They're all the same age so they're all going to go around the same time.)
https://linustechtips.com/topic/1624873-tpms-sensor-question/#findComment-16813657
Good to know. I'll check the place I go for tires and see what they charge to install them. I recall it wasn't that much.
https://linustechtips.com/topic/1624873-tpms-sensor-question/#findComment-16813660
If you have a Discount Tire or America's Tire nearby (same company), they're quite capable of doing the sensors and programming them correctly. The sensors alone can be $50+ each though, so prepare for a not insignificant bill. You can get OE equivalent sensors for $20 each on a place like RockAuto, but installing and programming would be up in the air.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
https://linustechtips.com/topic/1624873-tpms-sensor-question/#findComment-16813791
