Defined how?
Where is the "speed lower"?
Download speed tests show megabits per second (Mbps) which is how speed is sold by ISPs
A lot of clients show in megabytes (MBps)
8 bits in 1 byte so 100 Mbps = 12.5 MBps
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813472
Just now, Tetras said:
How do you know whatever you're downloading from can supply the speeds your Internet connection can do?
multiple places same speed or even lower my current one is steam and a friend from same provider has way better speeds
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813473
1 minute ago, Lurick said:
Defined how?
overall low speed but more download and yes i know that i should have around 950 mbps now not even 300 for download this is in fact all the time not just for the moment
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813475
Is this wired or wifi?
If wifi, distance matters.  Walls matter.  Closets, bathtubs, wiring, pipes, etc...matter.
I have 1.2Gbps Xfinity:
1.  Wired into router - 1.2gbps
2.  Wifi on phone next to router - 1.3 - 1.4Gbps
3.  Wifi to office upstairs and across the house - 350Mbps
etc.
Just now, x cxcxbvxbxxbxbxbxbx said:
enough considering i have same speed on wifi
WTF does "enough" mean?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813483
Most sites throttle downloads especially during heavy demand.  Also, as hinted above, Wi-Fi speeds are not stable and widely vary depending on where you are.
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813485
44 minutes ago, x cxcxbvxbxxbxbxbxbx said:
internet tester show high download speed but actual download speed is much lower
What speed does internet tester give? What speed does actual download give? Where are you downloading from? What are you downloading to? How are you measuring actual download speed? How are you connected? What plan are you paying for?
We can't help if you don't give us context
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813502
A website or service can run multiple servers and load balance between them. You might not get the same speed as someone else accessing the same site. Heck, you might even get a different version of the same site/service because they're in the process of migrating their instances.
Then there are issues of routing. Say you're in Greece and accessing a Dutch server and someone is in Sweden. You could both access the same Dutch server and get there at different speeds because one routing will go through Germany and another through Denmark. There are so many factors involved, even when it's not your own hardware/ISP.
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813514
Also those speed-testing websites will give you some optimal nearby servers to test against. But if you manually pick some more distant server, you'll get lower speeds. It depends vs which server you're testing your speed.
And when you access some other website, you will run into a different setup, maybe they don't have CDNs, the routing is not optimal, traffic is congested, etc.
Also internet speed might vary per time of day as the more people are at home, the busier the internets.
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813519
yeah the problem is that even close one are at about 300 to 400 considering it should be around 950 also i had this speed for moths now all day so it's not one time thing
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813530
etc.
image.pngpretty obviously
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813534
7 minutes ago, x cxcxbvxbxxbxbxbxbx said:
do you want the serial number of the case or maybe the number of screws in the pc what specs???????????
What the fuck kind of childish response is this?
You come in here, asking for help.
I ask a very general question that we ask almost everyone who comes in here, what are your system specifications?
I wouldn't be asking this if it wasn't valuable to us.
If you called a mechanic asking for help with your car, you would tell them what car you have, not just.. its red.
Good luck.
Sheesh.
If you don't know your system specifications, just tell us and then we can figure that out.
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813538
1: 320mbps learn to read
2: depends around 20 or 50 MBps
3: again do you epect to have a list of every site i ever download from? right now steam
4: aaaa? pc? do you want the partition
5: the one where you ask how i measure actual spee is very stupid google(brave) and steam literally tells you the download speed
6: i said that i get same speed on wifi IN THE SAME ROOM WITH THE ROUTER so considering this we asume it's wired witch it is wired ethernet
7: 950-900 mbps
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813543
Good luck.
Sheesh.
what specs do you need? do you expect me to tell you the specs of my psu? do you need the router? the drivers? the gpu? the cpu? i won't lay here all the pecs of my pc just tell what specs do you want and what part of enough don't get it means i checked my drivers router and pc can handle the speed at max of 1000 mbps my plan is for 900-950 mbps
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813545
weird is the fact that my upload speed is almost triple compared to download speed
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813556
Specs, and explaining what you meant by this, allow us to see if there is anything we may know or run across that conflict with issue, or can shed light.  We're not asking just to be dicks.  There are tons of issues that can arise simply from using an M.2 AND a SATA SSD for example, that very few people know, and it depends on the motherboard.
For example, my motherboard shuts off PCIe slots when I use all 3 M.2 slots. I didn't know this until I couldn't get my PCIe M.2 addon card to work.  I was stumped for a good while thinking it was something else completely.
But...best of luck.
I refuse to try to help those that give you shit for trying.
@Hinjima and I will probably get a warning for being assholes.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813557
But...best of luck.
 here specs everything also i said the same problem is on wifi to what do you expect the other one to be? and second yes i know my pc is bad but i ca n run at the full speed i have since the upload speed is close the download one is the issue and yes i did test my ssds they work fine image.thumb.png.bfa014a96eefb9076a2bde65f3994b0d.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.thumb.png.bfa014a96eefb9076a2bde65f3994b0d.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.png.1f9d8b5b61a1388a492b1c743792a01b.pngimage.png.9eab9af305b9d8c41ace769c1031180e.pngimage.thumb.png.4a81517d9c9c6c8578776ae57025c3c8.pngimage.thumb.png.01235f393f144031162d150ea7f9daf4.pngimage.thumb.png.a3640b78e05964a82585cd611a663519.pngimage.thumb.png.687a8bc4e7cd0423e590e11f59d4be11.png
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813568
Testing internet speed while using Wi-Fi is not accurate. Also the further you are away from the wireless gateway. You will have a lower speed.
https://linustechtips.com/topic/1624858-internet-speed-problem/#findComment-16813599
