i was reading this cnet article about Intel's new Core-m broadwell lineup  (not endorsing, i think cnet is the worst) and this comment
reminded me of the whole process shrink vs. heat debate. does heat reduce with the process size or the opposite?
https://linustechtips.com/topic/162464-14nm-heat/
I think heat might go down, but thermal density goes up (ergo hotter) but who knows what sorcery Intel does.
You're forcing less power into it, but at the same time into a smaller space.
Consider that if the heat from the flame of a candle were evenly spread across a 3m square area, it might be tolerable. If the heat from the flame of a single candle were evenly spread across a 3mm square area, it would probably hurt.
disclaimer: this is uneducated babbling
Error: 410
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162576
To clarify:
The overall power requirement i.e. Heat output for the same processing is lower. This means more efficient.
However, the thermal density will increase and it will be just as hard to cool really (actually depends on several factors and cannot be said as easy as that).
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162598
this^ pretty much hit the nail on the head.
if you halved the die size but kept the same number of transistors it should consume about the same amount of power and produce the same amount of heat except due to the smaller nodes less voltage is required so power consumption drops however theres less area to pass the heat to a heat spreader so temps often go up and you end up with 80*c haswells and likely 85*c broadwells, things like piledriver 8 cores often run at a much cooler 65*c but they have a relatively large surface so thier thermal output it higher (not nessesarily a bad thing as far as longevity goes).
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162600
a majority of the heat increase (excluding the TIM fiasco) was the
FIVR (Full Integrated Voltage Regulator) included on the Haswell base. note
the refresh and devils canyon, the possibility of putting the VR back onto the
motherboard should bring back normalized thermal processing.
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162604
ok now im really confused so what is it going to use more power than?
OKay, what I mean is in order to shove something into something small, you're going to add and use more power to do so. Relative to haswell, broadwell will use lets say 1/4th the power in the 5770k chip, than in the 4790k chip. But because of the smaller die it's going to use a but more power than that original 1/4th, so it may need to use another 1/8th of that power to get the same performance, while still using less power than the haswell chip.
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162612
oh ok gotcha now  ;)
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162635
Temps technically go down but smaller die size = less surface area to transfer heat.
FX chips run hotter than Haswell, but they can be kept under 60c with basic coolers like the 212, you'll struggle to do that with Haswell because it transfers heat from the cores so poorly.
Proof is a Haswell running at 80c won't really warm up your watercooling radiator, but FX8350 running at around 60c will cause it to belch fire.
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2162843
The heat goes down, as well as power consumption, but that is in case you have the same amount of transistors. (that is due to less voltage needed, and less leakage with FinFET)
But what does happen is that the heat density goes up, and since a die shrink means more transistors per die, you get more heat as a result.
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163636
The heat goes down,
This mean heat dissipation goes down?
I don't understand die architecture well enough to begin to make a guess on the heat. The wires in the silicon are smaller, will there be more of them or are they just shrinking the size and restructuring the engineering? If they increase the amount of wires would they have to have more transistors, and would this make for worse overclocking because you might be more likely to hit transmission delay? Or can they possibly engineer to improve delays?
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163771
There are very little wires in the chip itself, the transistors are made of silicon. And yeah what goes down is the heat produced when one transistor switched its state. This heat is very low, but you have billions of transistors so it adds up, and since they are smaller there is more heat per unit of area (heat density)
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163793
Isn't there wires connecting the transistors?
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163843
Not really, there are millions of copper interconnects between transistors.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163857
yeah basically really short wires, that have almost no resistance  (and hence heat) due to being much shorter than they are wide, and so the formula for resistance gives us a looow number
853a451ad123a6c08163b6cfdac958ef.png and since l is much smaller than A, and p for copper is low too, we get a number low enough to discard it
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163887
Well I think I've learnt a few things from you. You've opened my eyes a bit. Thanks.
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163913
Yes and no. The length actually adds up to a lot.And if copper wasn't a problem, then there would be no research going into using exotic materials (nanotubes) for interconnects... but it is.
Spent enough time on FE UNI to know a thing or two about electronics (shameless brag  :ph34r: )
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163919
Glad to have helped
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163920
Yeah id does add up to a noticable number, and they are researching new tech due to that, but compared to transistors, its still relatively low. The ratio is bigger with FinFETs since they dump less heat tho.
And yeah im at FMF Physics so i got and idea about this too ;) (shameless bragg) just that as a physicists i neglect results that are (comparably) unnoticable haha
https://linustechtips.com/topic/162464-14nm-heat/#findComment-2163934
