HI everyone. I built my computer recently with a 9 9900x and a 5070. The problem I am running into is cooling. My CPU stays around 80-85 while gaming, which I understand isn't a problem for the cpu, but I am also positive it is being thermally bottlenecked as that is around 20% utilization most of the time.  I currently have a noctua NH=U14S. I just bought the DH-15 just to find out that it is too large for my motherboard and covers my PCIE slot. My case only supports up to 240mm AIO, and I was looking at the  artic liquid freezer 3 240 and wondering if it would make any significant perfomance difference, or what AIO should I go with?
https://linustechtips.com/topic/1618808-i-need-help-cooling-the-cpu/
I never heard of a cooler doing that.
I thought all motherboards to be equal in that dimension's regard.
Did you try rotating the cooler ? (My cooler only fits in one direction)
Edited by leclod
If you don't quote us, we won't know you answered
I don't see the problem here. Those temperatures while gaming are completely fine and the CPU utilisation is probably lower because you are gaming at 2k or 4k and offloading all the work to the GPU which should be closer to 100% utilisation.
You're NOT CPU bottlenecked
CPU usage is 20% just because a game can't use more than a few threads
Your cooler is fine
Maybe undervolt your CPU with co
3 hours ago, jholbrook182 said:
gaming, around 20% utilization most of the time.
As @PDifolco said above, most games out there only uses some of the threads.
Some uses more than others.
Here's my 9800x3D with 360AIO
Wuchang: Fallen Feathers, 1440p
Me, I think I'd rather buy a good air cooler than a 240 AIO.
Like that NH-D15 you bought.
Unless it's SFF build or aesthetic matters lot, or somethin
That's weird, first I heard about it tbh.
You sure you installed it right ?
Refresh before you reply
This CPU is capable of 300w with PBO, you should probably use an AIO if you want peak performance.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
I followed all the instructions according to the manual.  It might fit if I dont offset it but I dont know if there are any downsides with that.
I would also prefer an air cooler,  but my motherboard (x870 wifi 6) gets it's first pcie slot covered when I install the NH-D15 heatsink
Well, offsetting is an optional improvement, if that's the only way then of course I'd do without
Found this in the manual :
On other AM4 CPUs, or if there are any compatibility issues
in the offset position (e.g. clearance with motherboard
heatsinks), please choose the standard position (0).
Edited by leclod
I see.
Seems Gigabyte being weird and switch the placement of 1st pcie slot and 1st nvme slot
Thermalright does not need offset mounts, I would run a PS120 EVO on the CPU.
You're not being thermally throttled.  The CPU is simply not using all its cores/threads, per the instructions of the game.
A CPU/Windows doesn't dictate fully how the CPU is used.  The game engine has to be able to take advantage of the additional cores.
That's why we recommend 6 and 8 core CPUs for gaming still.
You're about to spend money on a non-issue, and after you do... nothing will have changed for you.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
4 minutes ago, leclod said:
But 82° at 20% load would still be an issue
Depends on the load. Is something pegging 1 core?
OnePlus Ecosystem:
3D Printing:
