Looking to start more PC gaming, no interest in buying a PS4 or XB1 so eventually console games wont be available for my PS3.
Having come up through the generations of Playstations, I'm super comfortable with those controllers and I know PS3 controllers can connect to PCs but I've been told xBox works better???
So I need to figure out the best option, use the PS3 controller i have and i'm comfortable with or buy an xBox one. What is the best software for connecting them with???  Is there any advantage/disadvantage to PS4 or XB1 pads???
OR
are there any decent PC only controllers worth lookin into???
Win7 64bit, Asus P8 Z68-V/Gen3 MBoard, Intel i7 2600k 3.4GHz, Corsair H100 CPU Cooler, 16Gb Corsair Vengence, 120GB Sandisk SATA III SSD, 2TB Seagate 3.5" HDD, 500GB Seagate 2.5" HDD, EVGA GTX 570HD 1.28GB GPU, Corsair 750w PSU, Logitech z906 5.1 Sound System, PCI Firewire Card, Corsair Carbide 500r Case, Razer Lycosa Keyboard, Logitech G400s Mouse
https://linustechtips.com/topic/161774-best-controller-for-gaming/
the big difference between playstation controller and xbox controller is that when playing the game it will probably tell you the buttons from xbox controller instead of playstation. IT would take some getting used to. It mainly comes down to personal preference. If you buy a new controller definitely check out scuff gaming.
Computer: MacBookPro, Imac, PC to be build this year (2014)
Camera: Nikon D90, D200, D800, D7100 (Facebook: http://paradisethroughalens.blogspot.be)
Consoles: PS1, PS2, PS3
personally, i prefer xbox 360 controllers as im more used to it.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
http://www.motioninjoy.com/
Love it and I use it all the time. Just played through Watchdogs with my PS3 controller and this program and it was a lot of fun. Although, I have to admit you need to emulate an XBOX360 controller to mark it work well, but that is no problem with the "motioninjoy" program.
So I would save the money (and since I assume you have paid quite some money for the PS3, you might as well save yourself from spending more) and use your PS3 controller.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
The 360 controller is plug and play, and it will always work with pretty much any install of windows that isn't older than XP and you don't need software if the game supports controllers. As far as being best that's subjective, I hate the thumb stick layout of the PlayStation controllers and I always have so I use a 360 pad. There are also control compatibility issues to worry about, most of the time a game on PC will have controller support but it usually only works the best with a 360 pad. There are a couple of Logitech controllers that mimic the layout of a PS controller that you might be interested in if you don't like the 360 pad.
http://gaming.logitech.com/en-us/gaming-controllers
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Scuff controllers are pointless on PC, unless you are buying for aesthetics.  These controllers are for FPS console gamers. A controller is useless in an FPS game on PC(unless they have auto aim but even the a keyboard and mouse is more accurate).
X360 controller is good basic and easy to use controller, but not the best (imo). I prefer Logitech F710 over it and Dualshock would be my favorite IF it didn't require drivers and games supported the Playstation icons along with the Xbox icons. But yeah, if you just want something easy, then X360 is fine.
DS3 for PS3 Controllers, But Wired Xbox360 and Xbone(via micro to fullsized usb) controllers work out of the box most of the time (or with drivers straight from microsoft) and companies like RAZER and such make custom Controllers for PC Controller Gamers(don't personally use any but I seen some on Razer and on UNBOXTHERAPY on youtube he has a few different ones by different companies)  the custom controllers can be based on other existing ones,  or fully custom depends, and soon steam is making Steam Controllers :P
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
