"What's the best graphics card?"
How long is a piece of string?
The answer depends on your requirements. Do they need a ton of VRAM? Is this for CAD software like SolidWorks or AutoCAD? What resolution are they running? Is this for a workstation, or for final rendering of 3D animation?
15 minutes ago, EL02 said:
The company I work for needs
i presume they are using it with a specific piece of software, that piece of software should have a list of supported cards, they may even have them sorted into performance categories.
The best card in the world at the moment is the RTX Pro 6000, which officially costs $8,565. It draws 600W of power, so may require a power supply upgrade if you're putting it in an existing system.
If you don't care about price to performance, it's just the best.
1 hour ago, EL02 said:
The company I work for needs the best graphics card for 3D rendering. Maximum price is $10k.
Thanks.
The new A6000 is $10k iirc
But it's not worth the price over a 5090
Unless you have professional software that requires certified hardware, then it might not be an option.
Thanks
Thanks.
RTX PRO 6000 Blackwell with that budget. https://www.newegg.com/p/N82E16888892012
