SFP Conversion
Go to solution Solved by AbydosOne,
43 minutes ago, DraconisMaximus said:
I now need to plug an SFP cable into an ethernet port but cannot find a reversed adapter for that other than full converter boxes like these.
Yep, you'll have to rely on a media converter.
SFP modules (more specifically, the active chips inside) get their power from the device they're plugged into. If you run SFP to SFP, you need something on the far end of the cable to provide power, and Ethernet devices don't universally provide power. Hence, media converter.
I’ve used these to plug ethernet cables into SFP ports in the past.
https://techspecs.ui.com/unifi/accessories/uacc-cm-rj45-mg?subcategory=accessories-modules-fiber
https://www.amazon.com/sfp-media-converter/s?k=sfp+media+converter
I’m guessing there is some technical reason why the conversion is harder in that direction that requires an active device. Can anyone confirm if this is true / the technical details of it?
https://linustechtips.com/topic/1613985-sfp-conversion/
Typically SFP is used so you can put different fiber transivers into a port, so you can pick multimode or single mode for example for each port, instead of having to have different switch models. Generally SFP isn't used for long distance connections in walls like you would with fibre or twisted pair cables.
A bit more detail about what exact devices your connection would porbably help, but yea a media converter is often needed.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16741484
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16741527
its a bit like converting a door into a window and a window into a door.
most doors can be a window, some even support being a window by having glass.
when you try to convert a window into a door, well now you have a serious problem, there are no stairs on the other side, there is no path to get to it, the opening isnt tall enough to walk through.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16741536
Strong analogy there
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16741549
The ISP ran a PON terminated cable into the house. They included a PON to SFP adapter to go into their POS standard gateway. I have a Cloud Gateway Max/UCG-Max that only takes ethernet. While some some people may like the POS standard, I don't and getting a direct WAN connection is the first of many steps to eliminate the POS.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16742339
Any recommendations for a decent one? The ones I have been seeing run $130 - $200+ USD. I should note that SFP+ and 10GBase-T are necessary to get the full speed out of the system. I currently have a Cloud Gateway Max/UCG-Max and at those prices it may just be worth upgrading to a Cloud Gateway Fiber/UCG-Fiber.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16742347
And your ISP will provide you the information needed to do that and let you bypass their PON gateway?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16742398
I have talked to three different people at the ISP and gotten three different answers. BYOD is not banned but they would prefer you keep using provided hardware and so they don't make it easy. In any case, to even try I need a compatible connection to my own gateway.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16742478
Yeah typically when people do this they will buy a gateway that already has an SFP+ port, or run pfSense/OPNsense on a PC.
Or put the ISPs gateway into bridge mode so it acts as a media converter itself.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16742517
Just saying, those SFP connections are typically ethernet too, just a different standard.
A media converter is the best option unless you can get a router with sfp ports like the UDM pro.
https://linustechtips.com/topic/1613985-sfp-conversion/#findComment-16742518
