Proxmox help
Go to solution Solved by VXVaayu,
I'm back. Proxmox or ANY OTHER OS didn't work. apparently the NVIDIA gpu on it was completely bust and every os tried to ping it to display a gui, even non gui os(s). The laptop was apparently unsalvageable. So i've decided to recycle it after taking out the cpu, hdd, ram, wificard, etc. I've used all your advice on my new server(which is not up and running). Thank you for your help!
My laptop's gpu got fried after years of neglect. It's completely toast. Crashes instantly when displaying anything. But the rest of my laptop is pretty decent, so I decided to finally shift my minecraft server from free server hosting to dedicated hosting on my laptop. As there's no gui support (dead gpu and no igpu) I'm using proxmox terminal. I got to the stage of networking in the setup. None of the videos are providing with answers on what to actually do in this screen,they keep mentioning static ip, thing is, I don't know how to create one, can i create a static ip from a seperate pc connected to network? If anyone could list a beginner friendly guide to what exactly to configure and set in this screen,it would be much appreciated. I have no previous experience in hosting. Just trying to get my minecraft server going.
https://linustechtips.com/topic/1613275-proxmox-help/
6 minutes ago, Electronics Wizardy said:
FInd a unused IP on your home network range? We don't know what that is. What is your routers lan range?
Find a unused IP on your home network range that isn't in the DHCP pool or used by other devices and you should be fine.
How to find an unused ip? When i use "ipconfig /all"
In cmd on my main pc, all the ips are for either virtual lan software(zeroteir) or hyperV, only the HyperV ip has disabled DHCP, do I use that?
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16736618
What is your lan network range on your router? What is the DHCP range on your router?
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16736625
I'm way over my head,I'm giving up on this,I can't tell you what my lan network range or DHCP range are cuz I have no idea what they are or how to check them, thanks for trying to help, I'm gonna close the thread.
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16736634
Can you log into your router? That should give you more info?
What IP does your desktop have?
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16736640
Well, friendo, you have two options. The easy one and the valuable one.
The easy one is to can the idea and move on.
The valuable one is learning how to do some basic networking things. Assign static IPs and do port forwarding.
The choice is yours, but we're here to help if you want to learn
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16736719
If you only want a Minecraft server (and no other VMs), I would recommend skipping Proxmox and going right to a server OS like Ubuntu Server (or the like) and installing there.
FWIW (probably even more out-of-range, skill-wise), it's possible to run Proxmox with the IP handled by DHCP. You have to edit the /etc/network/interfaces file manually to change from static to DHCP, so you still either need a temporary static IP or direct terminal access.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16736740
  • 2 weeks later...
Proxmox isnt good for this, just use ubuntu server since that will be much easier. Proxmox is good for virtualization since it has a easy web interface, though if you just want a minecraft server and no VM's go with ubutnu server, its also easier to get a connection.
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16745969
  • 1 month later...
https://linustechtips.com/topic/1613275-proxmox-help/#findComment-16780539
