Right, so I've had a GTX 780 for around 22 days, now, first week or so I pressed it pretty hard in relation to overclocks, and the last week or so I've had pink dots in some situations, I haven't always been able to screencap it, but they do come around in Watch Dogs pretty much every session, and just today popped up in Skyrim
They're a pretty massive problem as post processing can REALLY blow them out of proportion
https://www.dropbox.com/s/3c62vibdxhse52k/72850_2014-06-02_00001.png
Above link is a screenshot showing the pink dots being post processed like mad
Anyone have any idea if I can fix this myself? - Warranty is almost guaranteed to be out of the window because of the OC.
Full model name: ASUS GTX780-DC2OC-3GD5
I'm pretty certain it isn't on the monitor level, as post processing in the games apply, and screenshots pick up the dots. I have NOT tested this theory.
All cables are fastened securely.
- Can anything other than the GPU cause this issue?
EDIT:
OC is OFF, and pink dots still appear.
Newest drivers from NVIDIA in use.
Pink dots appear in multiple games, just haven't caught screenshots of them in anything but Skyrim.
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/
Run the card at stock and see what happens. The DCU2 has a decent VRM, it shouldn't have become unstable over that amount of time, but best be sure about it.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2138889
Overclocking doesn't void your warranty unless you cook the thing with a non-stock bios.
They wouldn't put stickers and advertisements all over things promoting their overclocking software if it wasn't ok.
Have you tried different drivers?
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2138904
I have tried both the two newest drivers from Nvidia (A beta pre-Watch Dogs and the post-Watch Dogs non-beta driver) and reverting to the standard settings, I haven't had the thing overclocked for days.
how far did you overclock? Did you overvolt? if so how much?
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139034
RMA it back to them. You have broken something while OCing  :P... just out of curiosity what PSU are you currently using?
I'm using some 700W from Corsair, semi-modular, can't remember the name right now :S
EDIT: Sorry, I'm using the Corsair CX750M, so a 750W power supply, not a 700W
I bumped the max GPU voltage in GPU Tweak by 62mV, the Boost Clock was increased by 230 MHz, Memory Clock by 180 MHz and the power target (%) increased to 110%
I'm pretty sure all of this was pretty bad for the card.
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139060
q
That's well within the range that it can be operated at, what were temps during all this?
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139203
Maximum temp observed was 81ºC
I had one crash due to CPU fan not starting up (Forgot to plug it in) where CPU fan temp accelerated so fast the comp just decided to shut off, CPU was 75ºC after startup.
Average temps on the GPU was more like 50-60ºC, though, and I would stop gaming sessions when I reached 70-ishºC
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139219
Should be VRAM corruption, happened A LOT on ASUS DCU-II cards but mostly AMD R9 280x and mostly only in the first two months after the rebrand. Chances are you got a 780 that's been sitting on a warehouse shelf until now. RMA it.
Edit: OK I don't think that's VRAM after looking at the screenshot. Looks like a shader issue. Unless you've seen a checkerboard pattern at any point as well. Anyway, you should RMA it post haste.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139226
q
while I don't think it's damaged, I think maybe something was wrong with the card to begin with, and using it only made it become more apparent.
I'd recommend RMA'ing it, play stupid when you talk to the rep, usually it helps.
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139229
I can guarantee you it isn't a shader issue ;P
It happens across games, although all of them games where the GPU goes above 70% usage... And then it happens in Google Drive. The REALLY fucked up stuff is simply because shaders and post processing is then applies to the little pink dots - This is also why I am 100% sure it is a GPU fuckup, since shading is being applied to the dots.
I have a huge problem with the RMA process, currently sent in an email requesting tech support, but live support over phone is apparently not something they practice in Denmark (If you call and they guide you to their Components > VGA Cards then they will refer you to support.asus.com)
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139278
EDIT:
and verifying your game cache files.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/160671-gtx780-pink-dots-problem/#findComment-2139811
