FX8350 running hot
Alright so I reapplied and reseated my Evo 212, now I'm getting 56 while in battlefield 3 and about 36 idle. If I get a Thermaltake Frio, would there be any improvement? I'd like my CPU to be at 50C on load
I would not suggest that you get a Thermaltake Frio now. It was good when I bought it...back in 2010 / 2011...but since then, new CPU coolers are able to easily out-perform it.
Heck, I grabbed a Swiftech H220Water-Cooling kit to replace my Thermaltake Frio (but...two died on me within the 30 days of my initial purchase. Pump failure).
Remember, each CPU is never 110% the same. You may or may not be able to get 50*C during load.
If you are out looking for a new, better performing CPU cooler, have a look at some of these.
*Note 1: Keep note of the size of the coolers. They may be too big for your motherboard and/or computer case. Make sure before buying.
**Note 2: Some of these cooler can be quite expensive.
- BeQuiet! Dark Rock Pro 3
- BeQuiet! Dark Rock 3
- Nocuta NH-D14
- Noctua NH-D15
- Noctua NH-U14S
- Noctua NH-U12S
- Xigmatek Dark Knight II
If you want anything better, you'll need to look into water-cooling
***Note 3: Check compatibility of radiator mounting before purchasing. They may or may not be standard 2x 120mm / 140mm mountings.
****Note 4: for an example, the Neputne 280L uses a unique mounting for 120mm fans, and a newer 15mm spacing for 140mm fans.
- Cooler Master Neptune 280L
- NZXT Kraken X60
- Cooler Master Glacer 240L (improved, lesser to no problem, twin brother of the swiftech H220)
- Corsair Hydro H105
- Corsair Hydro H100i
- Corsair Hydro H80i
