Recently I was scrolling around on eBay for a CPU with bent pins that I could fix for some practice and maybe even flip. When I came across a listing that has a Ryzen 9 7900x listed for $125 with a seller that has over 10k items sold and according to the seller it doesn't boot at all. I followed up by asking him if he'd tested it on any other systems, and he responded with saying that he doesn't have the luxury to do so. Im wondering if this purchase is worth it, specifically as it is a complete gamble if it could work for me or not. I followed up by asking him if the CPU light turned on on his motherboard, and if he used any other chips in the system, he has yet to respond. Let me know what you guys think, any help is greatly appreciated.
Edit: guys I was just saying I was looking around for a CPU with bent pins not that the one I found was bent.
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/
If you are fine with losing $125 then sure.
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673559
Bent pins generally result in loss features rather than no post. If they include the picture of bent pins, check the pin out. If not, keep your money.
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673563
Ryzen 7000 series doesn't have pins, they have contact pads, the pins are in the socket like Intel. If the chip won't post, its possible its a bad board. Boards go bad more than CPUs themselves.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673566
Good luck finding bent pins on a CPU that doesn't have pins:
current PC:
PC configs I used before:
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673567
it's a lose considering AM5 has pins on motherboard side
current PC:
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673569
So OP was only saying that he was looking around for CPU's with bent pins and came across this seller with a 7900x.
OP never said that the 7900x would have bent pins, only a pre story to how OP got there.
But you are not wrong.
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673571
I think they "hope" it would have bent pins, but for this CPU it wouldn't work
current PC:
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673572
I was saying that I was just browsing for some cpu's with bent pins when I came across this listing not that the listing it self had bent pins.
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673576
Sometimes you get lucky and the seller tried a CPU that doesn't have BIOS support, but this CPU should be supported from the first BIOS release and with a CPU that is still actively for sale I'd have to ask: why didn't they just return it?
That said, there are A LOT of boot issues on AM5 boards that get misinterpreted, e.g. takes a very long time on first boot due to memory training, or cooler installation issue.
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673583
"lets go gambling"
jokes aside
if this is a yes then absolutely do not buy nor should you buy a chip with significant physical damage and if theres no info then still do not buy
the trick is to make it less up to chance and more like an informed decision instead of lets go gambling and proceeds to get an expensive paperweight, whenever i buy broken or half working boards i always ask details especially for ones with postcode or the ones that can sometimes turn on and other times not turn on and especially ask to test if possible cause whenever i miss any of these checks i tend to get an expensive paperweight most recent of which being a 16$ z87 pro4 (for reference got a working z97x soc at 30$ and theres a working mvii hero for 31$ available that im probably going to buy despite it being inferior to the soc cause resale value)
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673612
so they go as low as 300 new, it sounds like a motherboard problem but the seller might also not be telling the truth, i doubt u can flip it for much/worth the trouble, but for fun though? lol
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1604121-crazy-cpu-gamble/#findComment-16673621
