Building a home server / NAS solution
Go to solution Solved by Electronics Wizardy,
1 minute ago, Emzor_ said:
  • TrueNAS with ZFS file system
  • 2 VDEVs á 4 * 8 TB drives
  • RAIDZ2
Thats a odd choice storage wise. IDK drive prices there, but if power usage is a main goal, go bigger  drives like 16-24TB drives. If your in a high power cost area that will likely pay for its self.
I'd get a 8 drive raidz2, triple failures are unlikely and in that case restore backups.
If you want 50% usable space go mirrors instead.
3 minutes ago, Emzor_ said:
Boot & Cache Storage: Samsung 970 EVO Plus 500GB NVMe M.2 SSD
I'm pretty sure truenas won't let you use the boot drive also for cache, so get a second drive. But I woudln't get a cache drve here, get a pool for VMs and stuff that needs speed instead.
4 minutes ago, Emzor_ said:
OPTIONAL: Backup strategy? This is a optional question, but because family will also store data on this machine I am thinking about what I will do for backups. For me I wouldn't care too much, but with them in the mix. Are there any cloud backup services you could recommend? If not I may be just going with some good old hard drives stored with a friend.
You can price out cloud storage, think about $7 a tb a month is about the ball park. Offsite HDDs can work fine too.
  1. Budget (including currency): 2.200€ (2.270 USD) (a bit over would not be the end of the world, but it needs to be warranted)
  2. Country: Germany
  3. Aim:
    • It should be as power efficient as possible
    • The system should function as a NAS for myself and close family
    • Movie and Audio streaming
    • Development Server
    • Home Lab
    • VMs
    • Docker Services
  4. Software:
    • OS: TrueNAS Scale
    • Family connectivity:
      • DuckDNS to connect to my router with dynamic IP
      • Reverse Proxy to connect to the service which shall be exposed over the internet through DuckDNS
      • OpenVPN for connection to development services
      • Nextcloud for account separated access to data like photos and documents
    • Streaming: Plex for movies and series, audio has not been decided yet
  5. Other Info:
    • RAIDZ2
Hey there, I am currently in the midst of configuring a home server for myself and my family and could need some advise from the pros. The use cases I have already laid out above, but it is the first time for me to create such a system. In the future I actually want to have 2 different systems, so one can just be the NAS and media streaming server and the other the the development server / home lab. For now I will do everything in one single machine, out of simplicity and budgetary reasons, but of course if you see some better hardware I could use to have an easier upgrade path to a 2 system situation, please do not hesitate to point that out. I have made an initial plan on what software to use to accomplish my needs, but that of course may change in the future, I added it nonetheless because that may help some of you to have a better understanding of what I need. I have a few questions left before I want to go into buying all the parts. So I am going to lay out the planed build for you and then list the questions I have in hopes of some help from you guys, which would be greatly appreciated.
My planed build:
  • CPU: AMD Ryzen 7 5700G
  • CPU Cooler: Stock ?
  • Motherboard: ASRock X570M Pro4
  • Memory: Crucial Pro CP2K16G4DFRA32A DDR4 RAM Kit (2x16GB) 3200MHz
  • Boot & Cache Storage: Samsung 970 EVO Plus 500GB NVMe M.2 SSD
  • Data Storage drives: 4x Seagate IronWolf 8 TB NAS HDD
  • Power Supply: Seasonic Vertex PX-750 ATX3.0 750W Vertex PX-750
  • Case: SilverStone Technology SST-CS381 v 1.2
My questions are:
  1. Is there anything you would change about this build? Knowing what it will be used for, is there anything in particular you would change? I hope I didn't mismatch any parts, but this is not my primary forte so any head ups are gladly received.
  2. What would you recommend for fan configuration? I am either going to use the Stock cooler or one from Noctua. Which one would you recommend? Other than that, I am not quite sure how many case fans I would need and in which push or pull configuration. That's why I haven't listed them above. I want to make sure that nothing gets too hot even under load, but I have no experience with it.
  3. What RAID configuration would you recommend? I have looked into this a bit and I think I want to use the ZFS file system with TrueNAS. For now I would buy four 8 TB drives which will become my first VDEV. I thought I would use the RAIDZ2 which would give me 16 TB of usable space and quite a high fault tolerance, but would that be needed? If I need more space I would add another VDEV of four drives in the same configuration. I like the data to be as save from corruption as feasible, but should I rather use RAIDZ1 or another RAID altogether. What do you think?
  4. Do I need any additionals? Like cables or something like that, which I might forget.
  5. What about GPU? I am thinking about adding a GPU for hardware transcoding for PLEX for example at some point. Is that even needed and if that is something which you would recommend, what is a good card for my configuration?
  6. OPTIONAL: Backup strategy? This is a optional question, but because family will also store data on this machine I am thinking about what I will do for backups. For me I wouldn't care too much, but with them in the mix. Are there any cloud backup services you could recommend? If not I may be just going with some good old hard drives stored with a friend.
That would be all the info I could think of right now and all the questions I still have. I am more the software kinda guy, so hardware is not my real strong suit. I hope someone here can help me out a bit, so I do not make any dumb decisions and go into this as prepared as possible. Thank you all for reading and anyone helping I thank in advance also. Have a nice day stranger 🙂
https://linustechtips.com/topic/1600115-building-a-home-server-nas-solution/
  • RAIDZ2
