Stealth CD drive 900D advice
Solved by W-L,
I've seen this stealth drive idea done many times on the 650D and other corsair cases, I'm sure it can be carried through to the 900D in a similar fashion but here's the basic idea of how it'll be done on a C70, you'd mount the plate to the drive tray itself and have the corner you basically press to activate to open it.
Featured Topics
wolfgangam ·
Posted in Windows2 -
2
3
Joseph_Stalin ·
Posted in General Discussion4 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9
