Suggestions for fans
Solved by WoodenMarker,
NF-A14's are good. The R4 has 140mm fan mounts.Don't have those in my country only Scythe Slip Stream and no Noctua.
Already fixed with Asus. It was a mistake by the shop. And for Noctua there's only Noctua NF-A14 FLX
It's airflow, not pressure. Cases are not airtight.So as I assume it's a lie that positive pressure is better than equal or negative.
Positive airflow pushes excess air though cracks instead of potentially sucking in dust like negative airflow. Equal intake and exhaust is best for performance as the movement of air is best used to move heat of the case.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
