Best 80mm fan @ 7v?
flibberdipper
I'm kinda curious what the best 80mm fan is when it's running at about 7v. I would prefer to have the price under $10, and have the fan be black. Hopefully I can get my mom to order my dang Sentry Mix 2 this weekend.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
I like Nanoxia Fans. There is an 80mm one - http://www.pccasegear.com/index.php?main_page=product_info&products_id=23426&cPath=508&utm_source=googlebase&utm_medium=cse&utm_campaign=export_feed&gclid=CjgKEAjwtZucBRD77aiiq_v4xnASJABkAg8JDUpW8U4hGRpubhAcz8NMHG6vkgE5_GmTF-xhR0TamPD_BwE#googlebase
Now you are in Michigan and this is an Australian Site, and this comes with an adapter cable that will get it from 12v to 7v. Ill keep looking for one in the US/Canada region but this is probably what you want. I have 5 120mm ones and they are great.
Ill keep looking, Ill let you know if I find one.
Yo whats up.
Ok, so heres one on amazon - http://www.amazon.com/Nanoxia-Silence-1200rpm-NDS-80-1200/dp/B00CHW1B5M
If you dont want that get this : - http://www.amazon.com/Cooler-Master-Bearing-Computer-Coolers/dp/B005C31GIA/ref=pd_sim_sbs_pc_3?ie=UTF8&refRID=12QGMN0819E802GW0GR3
With this adapter - http://www.amazon.com/Phobya-Adapter-Converts-voltage-Sleeving/dp/B00943Q4C2/ref=sr_1_4?ie=UTF8&qid=1401407615&sr=8-4&keywords=7v+fan+adapter+cable
Hope this Helps!
BenestoTech
Yo whats up.
Main rig on profile
VAULT - File Server
Fractal design or noctua or noiseblocker all carry 80mm fans :)
