[Build Log] Blood and Ice - Another Prodigy Build
Bagmup
only slightly late for sniper elite 3 :P
Specs
Looks like I have my first problem, the DDC pump has shit itself already, ran fine over night leak testing, just starting to hear a noise coming from the pump, check HW Monitor and yep, idling at the desktop at 60 degrees.
Took the 24 pin out, put the bridging plug in and the pump constantly stop/starts, making a slight vibration noise...fuck me...
Couldn't be air? daaaaam....
I turned this bastard thing every which way last night to make sure all the air was out, like I said, it ran fine overnight and this afternoon while I was using it, it just starting making a weird noise about an hour ago and that's when I checked the temps.
Damn, and it looks so mighty fine. Hope you can get it sorted soon, after being so close.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
Cheers mate, I've already emailed Frozen cpu and am awaiting an answer. I don't suppose there's a frozen cpu rep on here anywhere?
So sorry to hear about that man! Hope Frozen CPU will be able to sort it out quickly
I just looked at frozens site, they're out of stock of the pump, friggin typical. Performance PC also has nil stock, fuck knows when this thing will be up and running again now..
Surely PCCG, TheKoolroom have a DDC or it's that you want to get it replaced under RMA?
I was just going to buy a replacement DDC so I didn't have to wait, anyone else I can try because neither pccg or the koolroom have one.
What DDC pump are you after? There are quite a few in stock at Frozen CPU
The Koolance PMP-400 should be all good, it's a DDC rebrand or the Swiftech MCP355 or 35X
SIMPLE MODZ
VAULT BOY - A Fallout inspired build  (Featured Build - December 2014) - GREEN MOLECULE - TOXIC CHROME - PARVUM FORMULA
Problem is I want the pwm controlled version and I also bought the EK Pump res combo from frozen, so they'll want the whole thing sent back I'm guessing. I can't tell if any of those have pwm control.
The Swiftech MCP35X definitely has PWM control, though that is also the more expensive one. Also I'm not sure if they'll want the whole thing back, just have to wait for their reply I guess
SIMPLE MODZ
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=613105&CategoryID=678
go go go!
EDIT: //Sorry I didnt realize you wanted the PWM version, that's the only one I could find in Aus without appealing on OCAU or something similar.
Sorry guys, I've been super busy the last week between life and sorting the pump problem, but... she is done. Big photo warning if you're on mobile.
FINAL PHOTO'S
428f30d7-725f-4397-8fcd-8dabf497d368_zps
It's been fun but damn, I'm glad it's done and i can finally play some Sniper Elite, even though I'm a month late haha. Hope you guys have enjoyed the log, it's gonna be a while before i do another, I have a rifle build that i put on hold to do this that needs my attention now.
Cheers, Jason :)
beautiful.
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
. . .  :wub:
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
What fittings are those @Bagmup
SEXY ones  :wub:
:wub:  :wub:  :wub:
What exactly is that res and pump combo? I am looking for a similar one in white, so i'm guessing you painted it?
