Can anyone help me? So I have a normal table with inputs inside td's. Now what I want to do is when the tr:last-child>td:first-child>input has something in it, a new row automatically be added. And then when you erase the value of tr:nth-last-child(2)>td:first-child>input, the tr:last-child should be deleted. Somehow the function work except to the dynamically added markups....
http://jsfiddle.net/7XZEV/
CPU: Intel Core i5 3570K ( raped to 4.4Ghz) | Motherboard: Gigabyte GA-Z77X-UD3H | RAM: Corsair Vengeance 8GB | GPU: ASUS GTX 980 Strix
Case: Fractal Design DefineR3Storage: 256GB Crucial MX100 & 1TB Samsung Whatevs | Display(s): ASUS MG279Q1x Cheap LG Shit
PSU: Corsair HX650 or something | Cooling: Corsair H80i | Keyboard: Ducky Shine 3 | Mouse: Roccat Kone Pure | Sound: SoundBlaster Recon3D PCI-e
It can't add the function to things that don't exist yet. You need to add the function to each new element you create or use something like .clone() on the parent element and erase the value in the field.
1474412270.2748842
By saying I need to add the function to each new element, what do you mean by that. I dont have much exp in jquery or javascript in general so if you wouldnt mind telling how to do that I would really appreciate it. And what if I have like a thousand row? Because in the project that Im currently working on right now, that is possible, wont the application become super slow if I add function to each of them? Isnt there any more efficient way to do this?
does this mean "i want that when you write in the last row, a new row should appear. then, when a row turns back empty, all the next rows should disappear" ?
so, your problem is that your script only works for 1 row?
there shouldn't be any problem
Well thanks for the help guys but I already figure it out a while ago at work...
