First of all, sorry, I have another topic that I posted 30 mins ago. I can't figure out how to delete it.
So I was playing Watch Dogs and:
"Display driver has stopper working and has been recovered" - flashing colors, pixilation, all around visual glitches.
Reboot and play Planetside 2 - same thing happens.
Mouse is freaking out.
Reboot - "Display driver has stopper working and has been recovered", mouse freaking out.
Reboot - "Display driver has stopper working and has been recovered", mouse not working, internet not working, keyboard spazzing out (press A once, types 40 A's).
Right now, if I reboot, everything is messed up right away, and I cannot connect to internet.
I am kind of freaking out.
Specs (2 days old):
i5-4670k
GTX 770
Fatal1ty z87 MOBO
EDIT: Just reinstalled Windows 8. Got chipset driver, audio driver, LAN driver, and GPU driver. Then (while on desktop) it said "Display driver has stopper working and has been recovered". Does that mean it is hardware, or is it a driver issue?
Nothing is OC'd.
https://linustechtips.com/topic/158198-so-many-problems-please-help/
as people say try to puut everything back to stock and if you have to clear the cmos. that should start to help the problem . just stock clock the GPu or even underclock it if you have to
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
You can't delete posts. Only mods and admins.
My recomendations for when a system gets "possessed;"
Return GPU, CPU, motherboard, and memory to stock settings and speeds if overclocking, which you say you are not doing.
Clear the CMOS
Full antivirus scan
Full antimalware scan
If the above does not resolve the issue I suggest the following to test the basic functionality of core components.
-Disconnect everything. PSU, GPU, Memory, the works.
-Remove the disconnected components from the case. It might seem like a pain in the @$$ but it makes the following much easier.
-Once the components are removed from the case give each of them a good physical inspection. Ensuring that nothing some how got damaged. Especially check power connection points for signs of short circuits. Ie melted wires or connection points.
-Rebild a "skeleton" system. This will help to check for faulty hardware.
        -connect the following CPU, CPU cooler, one stick of memory, psu.
        -once the skeleton is built then power it up and get into the BIOS to make sure that everthing is registering correctly.
-Continue until you have your full system put back together.
Given the problem started with the display driver disconnecting I'm inclinded to think its a faulty GPU or psu.
Try to run some very basic 3Dtests with the intergrated GPU.
Well I just reinstalled Windows 8, the GPU driver, LAN driver, audio driver, and chipset driver, but I got the message after while on the desktop after like 5 minutes.
Clear the CMOS
Full antivirus scan
What's your power supply? And try reinstalling the driver again, never know if it'll help doing it again.
a Corsair 600 watt modular PSU
ALSO: I never installed something called VGA driver on the MOBO driver listed because I figured it only applied when using integrated graphics. That true?
try running the system without the GPU, install the motherboard VGA driver..
uninstall the latest GPU driver you just installed
then try to check your GPU for bloated caps or any burned smell
try downloading a GPU driver 2 or 3 older than the latest
