Help with Setting Up WAN Failover
Just a last update - I was able to get everything working with the Cisco RV340. Quite the enterprise grade appliance and I like it very very much, was well worth the price and just plain works.
I left it in failover mode instead of changing both WAN ports to a precedence of 1 which enables load balancing. From there I configured the network detection settings to ping the Google DNS (8.8.8.8) instead of the default gateway, as it is unlikely my gateway would be disconnected from the Cisco router but very likely the AT&T gateway could be disconnected from the Internet (and thus the Cisco would not see that the connection is actually down). I verified the failover is working by unplugging the AT&T gateway from the ONT so all is good.
As far as the DHCP configuration and which subnets I used, whenever I put the ISP provided routers in bridge mode (passthrough), I noticed it just passes the public IP address over to the Cisco router (and I see these in each WAN connection on the Cisco admin interface), so it didn't really have any influence on what subnet the local network needed to be on. Regardless, I still changed the static IP and the DHCP server on the Cisco router to use 192.168.80.x as my work VPN uses the subnet it was originally using (just to avoid any weird issues).
The Ubiquiti U6+ AP is very nice, I mounted it on the ceiling in my kitchen which is central in the house and it has good coverage of the 5GHz band and excellent coverage of the 2.4GHz band. It gets about 600-700Mbps down when close to the AP, and the LAN connection on my desktop PCs are fully saturating the Gigabit connection.
Here is the media enclosure setup now (with the ISP provided gateways in other areas of the house):
Hopefully I have very reliable Internet now that I have two ISPs and automatic failover. Took a while to figure it out but happy with the results.
