Help with my power supply
aidanp
I have a corsair ax860.. will it run these specs? intel 4930k, amd r9 290x, 32gb corsair vengeance 1600mhz, 500gb evo ssd, 6 fans, a liquid cooler...
Yes, easily.
edit im a idiot
Specs
side note you may as well go 2011 and 32gb theres no point going 32 with 1150
The 4930k is 2011..
Yes it can, it will be more than enough. You could probably add another 290X even.
