So, am trying to fix a solar panel mount for a ring camera whose cable broke THE DAY I GOT IT. And so, l'm going to replace the cable, but the problem is that I have a donor cable with 2 wires/ 2 pin and one that has 4 wires/ 4 pin, but for some reason, the cable inside of it has 3 wires?!?!?!?!?!? Is this a normal thing??? Also how the hell do I wire it???
https://linustechtips.com/topic/1576981-3-pin-micro-usb-cable/
you peal back the rubber about half inch then you buy solder less connectors and you put one in each end and heat it up with a litor
https://linustechtips.com/topic/1576981-3-pin-micro-usb-cable/#findComment-16469553
Positive, negative, ground if I had to guess. Strip the black sheath and match the colors.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1576981-3-pin-micro-usb-cable/#findComment-16469567
I thought the black was ground? Also normal micro usb's have either just have the black and red for power or that plus a green and a white wire for data + and -, so where do I connect the ground to?
https://linustechtips.com/topic/1576981-3-pin-micro-usb-cable/#findComment-16470500
On your damaged device, black is most likely ground, red is most likely +, and blue is most likely -. This is the industry standard.
USB 2.0 should have black for ground per that standard as well, but you can always grab a multimeter and check.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1576981-3-pin-micro-usb-cable/#findComment-16470510
  • 2 weeks later...
