My i5-3570k oc to 4.2 ghz gets 50c on standby and 70c on load. Is that ok?
Desktop:  Cpu:                     3570K @ 4.2Ghz                    Graphics:          Windforce GTX 970             PSU: 1000 Watt EVGA
                Motherboard:       MSI GD55 Z77                        SSD:                 120gb patriot pyro se          KB:    K70 RGB
                Ram:                    8gb 2133MHz G skill               HDD:                 4 Tb                                    Mouse: M65 RGB
https://linustechtips.com/topic/157631-cpu-temps/
Yes.
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2100855
good temps, maybe a little high on idle, but still fine. What's your cooler?
Stock lol
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2100897
ok, what's your vcore? and what is the fan speed under load?
On cpuid hw monitor, cpu fan is always 100% and vid is 1.251V
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2100944
1.25V is quite a lot for a stock cooler, that explains the high idle temps. I'm surprised you're not getting much higher load temps... what do you stress test with?
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2100957
I haven't done a proper stress test on my computer.
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2100974
Personally I would not be overclocking with the stock cooler, especially as aftermarket air cooling is so cheap or even an AIO water cooler. But with those temps arent bad and should not have a detrimental effect on your cpu. Are you sure that is as hot as it is getting under load?
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2100976
aaah OK, I assume you where talking gaming loads, then. In that case I'd probably stay away from stress tests (includes things like rendering) as you'll likely hit 100°C with the stock cooler @1.25V. Either lower the voltage or get a better cooler. The hyper 212 is dirt cheap and will tremendously improve your temps, for example.
https://linustechtips.com/topic/157631-cpu-temps/#findComment-2101184
