Is liquid cooling safe ?
Go to solution Solved by GuiltySpark_,
Yes and no. However that cooler is plenty adequate for a 7700 and you absolutely do not need an AIO.
Why do you feel it isn’t up to the task?
You can comfortably air cool a 7950x with a $35 Peerless Assassin 120.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437129
1 hour ago, Cheersmate said:
know nothing about maintaining or changing parts of a pc
Then just get a better air cooler.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437133
2 minutes ago, Electronics Wizardy said:
What temps are you seeing with your current cooler?
There are larger air cooler options you can use too.
AIOs are generally pretty safe. The chance of failure that will leak liquid and destroy the system is very low.
50-60 on idle and around 80-88 on 3dmark timespy benchmark
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437135
2 minutes ago, MiszS said:
You really don't need liquid cooling, people usually get it mostly for looks, because there's a pretty small difference in the performance. Your best option is the thermalright peerless assasin 120se
I have seen that but ım worried it might not fit
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437136
That's completely normal and no where near any sort of danger zone. Again, why do you believe what you have to be ineffective?
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437137
Because the case sits next to me on my desk and while it isnt in danger zone for cpu it is for me because ı really cant game when there is an almost 90 degrees small sun next to me
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437141
Sure you can. You arent gaming on top of your CPU core die.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437143
That's not how CPU temps work. The heat being transferred into the room is measured in Watts and for a relevant number to reference, you'd have to look at the CPU Package Power in HWiNFO or Ryzen Master. The temperature is just of the CPU die itself, its not directly related to the heat in the room, at least not in the way that you're thinking.
If that was a 14900k at 300W but the die was only 75C, its dumping WAY more heat into the room than a little 7700 at 95c as the 7700 is probably pushing maybe 100W. (at max load)
Changing your cooler isn't going to affect the power (heat) being transferred into the room.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437148
That is completely normal and safe temperatures for the Ryzen 7700... The ıd cooling se 224 xt is plenty enough for this CPU.
This CPU actually comes with a stock cooler that is worse than what you have on right now and the stock cooler is plenty.
You do NOT need to change the cpu cooler.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437149
İll be looking at the pearless assassin model thanks for the info
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437155
Hey, you can lead a horse to water...
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437159
It gets way too loud and way too hot for my taste.
If it was me I would have undervolted it with PBO and tuned my fan curve to not be so aggressive first to see how it goes.
Now, Curve Optimizer undervolting takes some tinkering but if you can follow guides on youtube its not much of an issue.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437168
How often do you run synthetic benchmarks?  Is it loud during normal operation / gaming ?
I can understand the noise but the temperatures are well within safe limits.
The AM5 / Ryzen 7000 series of CPU's are actually DESIGNED to run at 95c 24/7.  They try to hit 95c before limiting power or clockspeeds.
The PA S120 is a good cooler and is well priced. If you want a quiter system then sure, go for it 🙂
But you might still see 'high' temperatures as this is what the CPU wants to do.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437173
Its not just that it also jumps to over70+ degrees from 50s when ı do something simple like opening chrome etc.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437176
And what makes you think that is a problem? because none of the things you said so far is due to your cooler but the way these CPUs are designed.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437177
That is also completely normal for this CPU architecture. The Ryzen 7000 jumps from 40-80 and back to 50 again all the time.
This is normal behaviour for the Ryzen 7000 series. You can't compare this CPU architecture with ANY other CPU's on the market.
They are very very different in terms of temperature limits etc.
It will do this with a Peerless Assassin SE120 as well.
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437181
I can link you two videos explaining how these CPU's work in terms of temperatures if you want so you can learn.
One is a bit easier to understand and one is very technical. Let me know 🙂
https://linustechtips.com/topic/1573383-is-liquid-cooling-safe/#findComment-16437184
