encoding questions
Go to solution Solved by Electronics Wizardy,
No intel iGPU supports av1 hardware encoding, so you need to do it in software. h.265 is the best quality suppoted encoding codec on the iGPU.
ok, so my computer has an i5-1400 in it. I want to use handbrake to transcode some video. Can the quicksync built into the cpu let me do av1 or do I have to use software encoding for that? Also what codecs does it support?
Imagine everything i have written in a Linus Voice/ linus tone (Spock live long and prosper gif here ,idk why tho, i guess i just want to say that i like star trek and am waiting for new seasons of the ongoing shows), But seriously, a lot of what i type only makes sense when said in a Linus tone from an older ltt video (circa 2017-2019 & now 2024-onwards) basically before he got a beard and a lot of it should make sense even in a Linus with a beard face.
also note as per the latest typing test on my laptop, my accuracy is 69%
I'm not weird/creepy, I'm just observant I have ADHD and am not on any meds for it because I don't want to and don't need to be on meds. i also may just be depressed. If you find other things around you depressing, are you depressed or are you surrounded by depressing things?
https://linustechtips.com/topic/1573278-encoding-questions/
2 minutes ago, Indian pc builder said:
i5-1400
i5-10400?
i5-14400?
i5-14600?
https://linustechtips.com/topic/1573278-encoding-questions/#findComment-16435985
1 hour ago, Levent said:
i5-10400?
i5-14400?
i5-14600?
my bad, 12400. typo
since h265 support is spotty among my smart tv's and such, i'll just use qsv h264
https://linustechtips.com/topic/1573278-encoding-questions/#findComment-16436093
