So I will be trying to build my first ever PC 😄 I saw a case (Logic Aramis ARGB Mini) and it looks pretty good, also comes with 3 preinstalled fans. Found a cheap motherboard too, (Asus Prime A320m-k) and I'm worried, if those case fans would connect to the motherboard without any problems. I read somewhere that just because those fans are ARGB, this motherboard wouldn't support them. I'm so lost atm 😄
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/
Welcome to the forums!
Funnily enough that was my last mobo, so I know it pretty well. (Side note I would go for a B450 if your budget allows, provided you haven't bought it already)
Firstly, you would need a fan hub as the board only comes with 1 chassis fan header
Secondly, you would also need an argb controller, as this board does not have nay kind of rgb connectors
You can find these 2 in one controller normally, both fan and argb
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432044
3 minutes ago, Julijans said:
Oh I think the B450 would be even better, because that A320m-k was 45euro (with a bad cpu), and b450 is 50euro. (BIOSTAR B450MHP) to be exact. Would this motherboard model support all these fans without fan hubs and a AMD 5 3600 & RX 5600xt combo?
Nope, same connectors
Also looks very bare for a B450
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432054
13 minutes ago, Julijans said:
But then why is the B450 better than A320m-k?
Sorry, I'm pretty new to this 😄
Haha its okay
Normally they'd be a lot beefier, but these 2 are at the low ends of each spectrum
A320 doesnt make much sense when B450 isnt much more, as B450 supports more features such as (normally) more connectors on the boards, better VRM's and power delivery for the CPU, and always better rear I/O
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432076
A bit more of :
PCIE lanes
USB 3 Gen 2
RAM slots (if you ever need it)
And OC support if you ever need it.
And of course, as ^ said, though differs from board to board, generally better VRM.
I have a huge bias against Biostar motherboard, so I'm not gonna endorse it.
41 minutes ago, Julijans said:
Such a fast answer actually 😄
We don't sleep here, we stay awake until we faint.
Refresh before you reply
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432081
5 minutes ago, Julijans said:
Then what motherboard would be good for AMD 5 3600 & RX 5600xt combo? Cheapest option 😄
Looking for dirt cheap I guess this will do - ASUS PRIME B450M-A II, AMD AM4, MATX, 128GB DDR4, 4DIMM, HDMI, DVI, D-SUB, PCIE : Amazon.co.uk: Computers & Accessories
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432086
11 minutes ago, Blasty Blosty said:
Cheaper through PCPP btw, (UK region).
Though there are several other options as well at the same price.
Silly old me forgot euro exist (slap own cheek)
Edited by Poinkachu
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432093
I've noticed at this price range they're all kinda the same lol
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432098
word
I have ASUS PRIME B450M-K II, it can handle 5600 decently, only has one M.2 slot I think, still decent, has like 6 USB ports at the back I believe
current PC:
PC configs I used before:
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432108
Just now, podkall said:
word
Well, i don't really have VRM fetish to go in dept about it.
For AM4 I usually just kinda refer to this forum's mobo tier list ngl
My own pick would be the MSI B450M-A Pro Max at £56.21
https://www.amazon.co.uk/MSI-B450M-PRO-MAX-Motherboard/dp/B07WC8QVCB
Though from quick glance at spec sheets the ASUS seems to have better rear USB I/O and more Sys_Fan header (1), but yeah, probably because I don't use that much USB3 10gbps port.
Also kinda due to not having trouble with my last two MSI board.
So yep, kinda bias warning 😬
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432111
could work, since it looks completely similar to the ASUS
seen, but I'm biased towards MSI for recommending on AM5, those boards look so clean, and sometimes quite a bargain
current PC:
https://linustechtips.com/topic/1572824-logic-aramis-argb-mini/#findComment-16432116
