Community Fibre ONT pfsense elimination of double natting
Sir Asvald
Hello all,
I am trying to setup my Pfsense as the main "router", I want to connect the ONT to my Pfsense box and for it to get the Public IP address, how would I be able to do it?
Below is my current network and my planned network.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
Whats that program called you used in picture. (I used it before)
As for the setup, you'll need to work together with isp to set it up correctly.
My IT coworker has managed fiber connection to the pfsense by talking to provider and setting it up.
Not sure if it's same for you.
(Basically provider gave us vlan information and it worked)
Unless it's normal isp router then you'll be able to get dhcpd from ont anyways?
I'm jank tinkerer if it works then it works.
Regardless of compatibility 🐧🖖
Software is called Cisco Packet Tracer.
It's normal router, it's a Linksys MX5600.
Then I don't understand what you're need.
I'm seeing you're networking experienced.
To me it should same functionality.
All it's changed that if you remove isp router and just connect it, it will take over and become main router.
Since if i understand correctly its functioning as dhcpd client just like isp router?
You could copy configuration from isp router and configure into pfsense.
Unless those switches needs to be configured and put into vlans to the pfsense?
My current setup, my network is double natted, which is causing issues... I want the Pfsense box to replace the Linksys router and use the Linksys as a AP.
I also have my on Homelab which I want to keep separate.
Then i would consider using vlan, that would make connection that communicate between two points into one single point connection it seperate with other connections.
Would that solve issue you're having?
Sorry for not being clear, I do have VLANs setup. Since my lab is hosting a few services, it's causing issues. Not only that, I have a site to site VPN as well, which is having issues connecting back to my home lab.
I’m confused… if you have a linksys router acting as the edge router, and you want pfsense to be your edge router……. Just put pfsense immediately after the ONT into the edge router “position”.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
That's what I want to do, my main question is that I want the pfsense router to receive the Public WAN IP from the ONT, I want to know how I can achieve that..
Is it a standard ONT or an ONT Router Combo? A standard ONT it should just be plug and play. A combo you need to look in the settings for bridge mode or IP pass thru mode. Either of those two settings should do what you need.
A standard ONT.
A standard ONT.
Then just plug pfsense WAN port into the ONT. Just replace the linksys router with pfsense.
