I wasn't sure if I should put this in GPUs or the cooling section, but here it is.
I'm running two GTX 770s in SLI. When under heavy load, one GPU is reaching 75 C while the other is getting up to 90 ish C, due to having next to no room to breathe. I have two questions.
Firstly. Is a temperature in the 90s even safe for my GPU in the long run? Also, is there a reasonably cheap liquid cooling solution available? I've already got a H100i for my cpu so I dont really want a custom loop. Would the Kraken G10 + cooler be my best/cheapest option if I wanted to go AOI for my GPUs? Thanks!
i5 4670k @ 4.4 GHz | 16GB Corsair Vengeance | GTX 770 SLI | 256GB Evo Pro SSD | 2TB WD Blue | Corsair 350D | Windows 8.1 |
Asus VG248QE 144Hz Monitor | Roland Quad Capture Interface | Krk Rokit 6 Monitors |
https://linustechtips.com/topic/157143-gpu-temps/
no it's not safe specially for a nVidia GPU, and it isn't also on the long run
get better airflow case or a larger case to give it some breathing room, switch to a test bench, or do the most extreme solution, as you said, go for a custom loop, so juet get a kraken or koolance water blocks for em with a powerful pump, water cooling em will be the best bet
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094326
90c is perfectly fine, Kepler is a variant of Fermi with less per clock horsepower.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094332
come on Recon, if it was a AMD GPU, huum yes, you could say that, but for nVidia, even for Kepler based GPU, it's dangerous, specially for the long run as he stated
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094341
No, silicon starts to get toasty at 110cc, 90c is painless for a GPU, but you may not like the heat dump, GPU's are far stronger than you think, usually the power deilvery will collapse before the main GPU does.
Clock for clock proof:
980mhz 660Ti
post-60862-0-20293800-1400554801_thumb.p
My old 891mhz GTX 480:
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094354
90c is the absolute maximum temperature for those cards. Usually the profiles in GPU boost 2.0 set 80c as the max
if you run your cards at 90c you can expect them to last less than 2 years.
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094360
Set by Nvidia, they can do more than that safely.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094362
As I said. I can't really afford a custom loop as these tend to get very expensive. I'm thinking of 2 G10s with two AIOs. Does there happen to be an all in one with two blocks? Or am I going to need to get two seperate ones.
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094366
Still, it's steps away from throttling temp men, and for the long run, it does shrink the life span of the GPU doesn't it
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094368
have you seen the fast as possible with safe temps here's a link and i would recommend the kraken and those temps are really scary you should indeed get the kraken
did you mention the kraken because I think you forgot to mention the kraken indeed this guy should get the kraken. kraken.
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094369
Really you do not need any kind of AIO on a GPU, i suggest you look at this:
http://www.scan.co.uk/products/gelid-solutions-icy-vision-vga-cooler-for-ati-amd
Out of stock atr Scan, but they are amazing coolers, it is what cooled my 480's back in the day, look above for temps...
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094377
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-770/specifications
The max temp on the NVidia site is 98 C, so I think i'm okay, though I think I might still get some extra cooling going (because I can't help but want to mod my rig).
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094378
No evidence of it shortening life span at all, voltage does however.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094380
Wont this run into the exact same problem I have now though? My top card cannot get any air due to being so close to the bottom card. So getting another fan cooling option will be exactly the same as I have now.
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094383
two seperate ones i think, but i believe that for a dual Graphics cards config, if not a custom loop, i would prefer to have it on the motherboard box than have it hitting ludachrisly temps, that's what i did for a month when i first built my rig and din't have my test bench delivered yet,
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094388
Your card is significantly more efficient than a GTX 480, and even 480's were cooled massively.
Do you have room for 2x almost 3 slot GPU coolers, as long as you have more space than i did, you will be minted.
Image:
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094391
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094396
Image:
I'm running in an Obsidian 350D with an ASRock Z87m extreme 4. So space is rather limited for me. I cant being going for huge direct fans.
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094407
This would be fine:
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094419
believe me, it does
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094421
believe me, it does
What do you think killed my GTX 480?  heat or voltage?
Do look at the posted image before vs the 660Ti.
Le Bastardo+
Red Alert
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094433
This would be fine:
The bottom PCI-e port is 2.0, not 3.0. "PCI-e 2.0 x 16 slot (pci-e x 4 mode)" As opposed to slots 1 & 3 which are both 16/8x. Will this make a significant difference to my performance?
https://linustechtips.com/topic/157143-gpu-temps/#findComment-2094450
